Rough In Outlet Support Wood - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-01-2009, 12:15 AM   #1
Question
Rough in Outlet Support Wood
Need to add wall frame for dry walls, should I remove those woods?
Thank you very much!
Rough in Outlet Support Wood-img_0326.jpg   Rough in Outlet Support Wood-img_0327.jpg
legendbb is offline   Reply With Quote
Old 08-02-2009, 09:28 AM   #2
Remodeling Contractor
yes. But read more on basements. any wood in contact with concrete needs to be pressure treated. The walls in a below grade basement need to have a 1/2" or more air space. Foam board insulation is placed on the concrete, then an air space then the wall studs.
Old 08-02-2009, 06:59 PM   #3
Thank you very much Bob,
Just got a big ripping club for the wood piece,
My house was build in 1996, builder just left the wood on the concrete, home inspector didn't say any thing about it.
A further question is, to copy the same method used on partially finished wall frame, there are #15 (HomeDepot Canada so called) black sheet. In HomeDepot they have huge roll, but my wall size is just <10m long. Any alternative? or I can simply ignore it.
Note: The wall I need to frame is a shared wall with my neighbor (Row Townhouse), but I don't know what in there. Some said there is a gap between two foundations.
Great thanks,
Old 08-02-2009, 07:16 PM   #4
now you are dealing with something different. No moisture transfer is likely to occur between this wall. And no space is likely between you and the next townhouse. #15 felt will work to protect framing lumber from the concrete. It's cheap ($15) or so.
Old 08-02-2009, 10:58 PM   #5
Got you,
Thank you again Bob!
Question closed.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
washer/dryer frying my outlet dontwannadiy Electrical 15 07-27-2009 11:52 PM
loose outlet boxes on metal studs windowguy Electrical 7 01-29-2009 12:12 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
