Rotate Shed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-17-2010, 02:03 PM   #1
Rotate Shed
Any ideas on how to rotate this shed? I'd like for the doors to be facing foward with right side of shed agaist tree and left side against fence. Thanks in advance!
kennnethpedward is offline   Reply With Quote
Old 08-17-2010, 04:35 PM   #2
Rewards Points: 506
depanding on how it is sitting/secured tot eh ground, I'd probably either; pick it up, lever it up, or just pull and push it with a small tractor. you could do the later with a truck and some old tires as bumpers.
forresth is offline   Reply With Quote
Old 08-17-2010, 06:52 PM   #3
Rewards Points: 2,716
I think you'd need a bunch of very strong guys to lift that up.
bob22 is online now   Reply With Quote
Old 08-17-2010, 09:28 PM   #4
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Easiest way is to just empty it, and get 6-8 guys to lift and spin ( like we used to do to VW bugs back in college)
If that's not practical get about 4 legths of 4" Sched 40 pvc pipe. lift or use a car jack to put pipe under the shed. once you get all the pipe under it you can push the shed around you yard, just have someone to grab the pipe that is left behind, and move it to the front as you go
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-17-2010, 10:22 PM   #5
Old School
Willie T's Avatar
Two hand truck dollies (strong ones), one at either end will do an effective job.
Willie T
Old 08-18-2010, 10:15 AM   #6
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Is it sitting on blocks?
CoconutPete is offline   Reply With Quote
Old 08-18-2010, 08:27 PM   #7
Old School
Willie T's Avatar
http://www.protoolreviews.com/how-to...ge-garden-shed
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
kwikfishron (08-19-2010)
Old 08-18-2010, 08:37 PM   #8
Last house I took my 4wd SUV out back & moved the shed with a rope & some fence pipe as rollers
Used a tire to push one corner back
Old 08-18-2010, 09:35 PM   #9
Registered User
Rewards Points: 526
With the 5 pier blocks I can see under it, (as C.P. said) all the options are correct, after you set new piers to correct grade elevation and location.
Dave, did you even read posts #2 and 4? Or Willie's last post........
Be safe, Gary
Old 08-18-2010, 09:48 PM   #10
Yes, did you read my post ?
Old 08-19-2010, 05:39 AM   #11
kwikfishron's Avatar
Rewards Points: 818
Originally Posted by Willie T View Post
Willie nailed it.
Surprised it took 6 post to come up with that one.
How do you move your hot tubs?
kwikfishron is online now   Reply With Quote
Old 08-19-2010, 07:53 AM   #12
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Originally Posted by kwikfishron View Post
Willie nailed it.
I'm feeling like Rodney Dangerfield.....
Old 08-19-2010, 08:15 AM   #13
Old School
Willie T's Avatar
We love ya, Chips......... but videos trump everything.
Willie T
Old 08-19-2010, 12:04 PM   #14
Rewards Points: 818
Sorry Chips, when I got to 6-8 guys I shook my head, stopped reading and moved on.
Old 08-19-2010, 12:25 PM   #15
Do work
Rewards Points: 81
A friend of mine moved a shed from the front to the back with this method. Jacked it up with a car jack. Installed PVC pipes under it and rolled it. Worked good.
liquidvw is offline   Reply With Quote
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
Drainage for Plastic Shed on Wooden Platform AikiPapi Building & Construction 7 07-29-2010 11:35 AM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 11:59 AM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 11:09 AM
Shed Wiring bcdal Electrical 12 03-26-2008 04:51 PM
