Roof Uplift On Open Building - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By aquacruise
Old Yesterday, 06:25 PM   #1
Rewards Points: 8
Roof uplift on open building
This is a new open building garden gazebo I have recently completed as a DIYer at my family home in the Caribbean. I am happy with most aspects of the building, and I believe I have given correct attention to downward forces, outward thrusts, bracing, and bending moments. However, I am not happy with my mitigation of upward forces (uplift due to wind) and this is obviously especially important in the Caribbean where we are prone to hurricanes! So this is why I'm here, hoping someone can advise...
Here is the basic sketchup design (with some rafters etc removed for clarity) and photographs below. Dimensions of the box section are 27ft x 17ft. Eaves overhand a further 18". Ridge height is 12ft from ground. Posts are 8ft tall. Rafters are 3x6, 2ft apart and doubled up at each end. Ridge is 3x12. Pitch is 26 degs (6 in 12). Perimeter wall beams & central rafter tie all 3x10. Posts 6x6. Diagonal braces 3x6 & 3x3 respectively. Roofing 1x6 v-joint covered in stone slates. Wall beams / rafter tie connected to posts with 1/2" s.s. through bolts, posts structurally tied to adequate concrete sub base (7" 4000psi, BRC + 1/2" rebar). Everything else screwed with 10 x 3 1/2" deck screws (6 screws per rafter, 3 at each end)
Sketchup
Overview
Roof
I'm fairly confident with my structural tie down of the posts, and the wall beams / rafter ties. My concept of the structure was for the ridge timber to essentially just be a ridge board, however since there are only 3 rafter ties (3x10, one at each end plus one in the middle, so they are aprox 13'6" apart) I decided to go for 3x12 ridge timber as I considered it to be a ridge beam (rather than board) between the the rafter ties, so I didn't want it to sag and create outward thrust pushing out the wall beams. Anyway, that all works fine, I fitted a stone roof (aprox 7,000 lbs roof tiles) with zero deflection to wall beams and zero issues. And we don't get snow here!
But I am concerned about uplift forces, which (for the life of me, I can't understand why given that I live in the Caribbean) I haven't given any consideration to...and we are entering hurricane season. I am fitting simpson strong ties x 4 to each rafter (2 at the wall beams, and 2 at the ridge, so both sides at both ends). Shown here:
Hurricane ties at ridge (Simpson H4 left & right pairs)
Hurricane ties at wall beams
That satisfies me at the wall beam end, but I keep looking at ridge and am worried that nothing is holding the ridge beam/board from potentially rising up in a hurricane...
Are the simpson ties at the ridge good enough? If the ridge tries to rise up, the 3 rafter ties will go into compression and prevent this? Or do I need to add collar ties? I'm hoping to avoid collar ties as not to ruin the aesthetics, but if so needed was planning to have some fabricated out of 1/2" steel bar and placing 4 across the building (so just under 8ft apart each) around 1/3 down between ridge and wall beams.
Please let me know your thoughts. And yes, I know...I really should have thought about this and asked BEFORE picking up my tools...but the original project was a lot smaller, I did the whole thing myself, and I probably ended up biting off more than I could chew.
aquacruise is offline   Reply With Quote
Old Yesterday, 06:42 PM   #2
Property Mgt/Maint
Rewards Points: 6,240
Re: Roof uplift on open building
Nice job with the build. I will let others decide on your actual question.
But the first thing that jumps out at me is framing with deck screws. Sorry, big no-no.
Deck screws are heat treated (hardened) and somewhat brittle and will break in time from fatigue. Lateral forces form winds will help this along.
I wouldn't necessarily pull the screws out, but I would go back and add the required framing nails.
[political signature removed]
Yodaman is online now   Reply With Quote
Old Yesterday, 07:02 PM   #3
retired framer
Rewards Points: 14,020
The three ceiling joists or rafter ties hole the roof straight, uplift in the center is looked after with collar ties in the upper third of the rafter.
The correct phrase is actually “collar beam.” ... A collar tie is a tension tie in the upper third of opposing gable rafters that is intended to resist rafter separation from the ridge beam during periods of unbalanced loads, such as that caused by wind uplift, or unbalanced roof loads from snow.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old Yesterday, 07:07 PM   #4
retired framer
Simpson's do make nicer looking hardware for nice building like that.
https://www.strongtie.com/decorative...ctors/category
Old Yesterday, 07:13 PM   #5
Rewards Points: 8
Yikes, just googled that, and you are correct! What about the simpson strong ties, will they not take up the slack? I certainly couldn't now remove the screws, but even getting nails in would be extremely difficult, given that the v-joint is now laid and roof tiles fitted...
Old Yesterday, 07:15 PM   #6
Rewards Points: 8
Thank you...it's all about availability here, not many hardware stores as it is, and generally have to go with what they've got on the shelf... (importing takes weeks and is very costly). I will paint them brown when fitted so as to hide them.
Nealtw likes this.
Old Yesterday, 07:16 PM   #7
Rewards Points: 8
The correct phrase is actually collar beam. ... A collar tie is a tension tie in the upper third of opposing gable rafters that is intended to resist rafter separation from the ridge beam during periods of unbalanced loads, such as that caused by wind uplift, or unbalanced roof loads from snow.
Thank you - so the question is, do I need to fit some collar beams or will the simpson ties do the job?
Old Yesterday, 07:23 PM   #8
retired framer
You need something that will hold the rafters together but you can do more than just nailing a board up there.
https://www.pinterest.ca/pin/207095282841778987/
Old Today, 07:13 AM   #9
Property Mgt/Maint
If I understood correctly, you mentioned 6 screws per rafter, 3 at each end.
That really is not a lot. Typically there would be 4 to 6 framing nails on each end, tow nailed into the lower and upper beams. If nailing is not a option, then consider adding structural screws in lieu of the deck screws. And yes the hurricane ties are a must.
There are several on the market, here is just one example https://www.grkfasteners.com/product...ructural-screw
