Roof Rafters Help - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 07-21-2018, 12:26 PM   #16
Neal I considered possibly an I-beam across the span but the only ones I can find are 8+ inches. Max I can do is 6”. I also considered possibly a couple really nice 2x6 sistered together across and then the rafters over that.
Jd1984 is offline   Reply With Quote
Old 07-21-2018, 12:33 PM   #17
The first 2 pics are of the exterior of the wall.
The other showing where the 4x4 rafters meet the header and tie into the other part of the living room roof.
Roof rafters help-677af882-d7b8-4092-86e1-2fd28e524bb1_1532190758654.jpg   Roof rafters help-927b94e6-931c-4761-bff5-b471a9573ea7_1532190774333.jpg   Roof rafters help-b97fcd61-60a2-4fdd-b0bc-cb66d9c3d980_1532190818467.jpg
Old 07-21-2018, 12:37 PM   #18
retired framer
Rewards Points: 6,230
Re: Roof rafters help
Originally Posted by Jd1984 View Post
Neal I considered possibly an I-beam across the span but the only ones I can find are 8+ inches. Max I can do is 6. I also considered possibly a couple really nice 2x6 sistered together across and then the rafters over that.
I would go bigger, even if that brings you below the ceiling. There is nothing you can buy or build today that will match the strength of that old beam and it sagged.
How high are the top if the walls?
Old 07-21-2018, 01:14 PM   #19
Top of the walls are about 7’ 8”. Almost 100 years since the living room area was added, id sag too lmao. It does not help the beam strength wise thay it is not sitting on edge. I have always heard that is the strongest way
Old 07-21-2018, 01:43 PM   #20
Rewards Points: 36
Indeed, very interesting thread
pandes is offline   Reply With Quote
Old 07-21-2018, 01:43 PM   #21
retired framer
They do make a 3 1/2 x 5 1/2 LVL but I am no engineer and I would like to see bigger, but's your call.
https://www.westfraser.com/sites/def...da%20v0415.pdf
A-frame roof to flat roof connection "slippage" miamicuse Building & Construction 11 10-01-2016 10:01 PM
Integrity of roof rafters williams_run Roofing/Siding 4 06-10-2015 07:41 PM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 04:17 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 01:47 PM
garage roof insulation between rafters denverman71 Building & Construction 1 10-21-2009 01:06 PM
