Rim Joists And Column Footings, A Series Of Questions - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By jlhaslip
  • 1 Post By Bondo
  • 1 Post By Nealtw
Old 04-25-2018, 01:28 PM   #1
Rim Joists and column footings, A Series of Questions
Hello forum goers.
This might seems like really obvious questions, but I have been struggling to find an answer.
I have read Canadian Wood-Frame House Construction a few times, but it glosses of these particular areas.
how do you construct a rim-joist when you do not have a single board long enough? Is it the same as header boards, just overlap a second layer? And when, if ever, do you use hangers to connect the floor joists?
When using a standard basement style foundation, the joist it held in position firmly by the sill plate. How how does it work with column footings? Does the beam (supported by the column footers) travel along the very edge of the floor, completely supporting the rim joist in all cases?
Thank you for any and all help and clarification.
wisnoskij is offline   Reply With Quote
Old 04-25-2018, 04:39 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Rim Joists and column footings, A Series of Questions
Rim Boards are butted up together and a splice can be added on the inside to help join them. That works when there are no joists landing at the seam. When they have a joist at the joint location, simply nail each piece of the rim to the joist.
Joist hangers are not required where the joists and rim boards are resting on the Sill Plate.
Hangers are required when the joists and Beam are at the same elevation, ie: there is not a Beam for the joists to land on. Nails alone will not carry the weight of the joist load, so a hanger is used. This is called a Flush Beam where I work.
Sorry, but I do not understand the last question, so can't answer that one.
wisnoskij likes this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 04-25-2018, 04:53 PM   #3
Thank you jlhaslip,
That is everything I need to know.
The Following User Says Thank You to wisnoskij For This Useful Post:
jlhaslip (04-25-2018)
Old 04-25-2018, 06:11 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,444
Ayuh,..... If I'm readin' this right,.....
With a post or column foundation, there's horizontal beams on top of the columns,.....
The floor/ platform/ deck is built on top of the horizontal beams,.....
Then of course, the walls on top of the platform,.....
Old 04-25-2018, 06:56 PM   #5
retired framer
Rewards Points: 16,998
Or you can use the beam as the rim and then you would use hangers.
Nealtw is offline   Reply With Quote
Tags
columns , floor , footings , rim joist
Jacking up house, full length joists raised beam off of center colums. Suggestions? slowjo Building & Construction 9 09-16-2014 06:56 AM
Column location for LVL Beam Perry401 Building & Construction 1 09-10-2013 11:27 PM
can i remove this lolly column? jizzem Building & Construction 10 09-30-2009 05:36 PM
Installing a structural fiberglass column Weekend Warrior DIY Building & Construction 9 11-19-2007 12:33 PM
