Rim Joist To Sill Simpson Brackets? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-11-2016, 11:56 PM   #1
Rewards Points: 310
Rim joist to sill Simpson brackets?
Not called for but I can't see the harm of adding brackets to add additional strength at rim joist/sill connection. I'm in earthquake country. I did see an article about how sometimes what seems logical in earthquake retrofitting you can cause more harm...
PandJ is offline   Reply With Quote
Old 04-12-2016, 01:16 AM   #2
Registered User
Rewards Points: 526
Re: Rim joist to sill Simpson brackets?
I-joists in CA? Usually the shear sheathing panel breaks at the rim joist center, with 9' sheets installed vertically (no blocking at edges required then per seismic zone) vs, horizontal application. That is why the engineered floor layout usually calls for double joist rather than single rim- WITH the 2x 0R double ply added in the space for full nail penetration for sheathing wall lateral shear. Length of braced wall line is from (just past) threaded rod to threaded rod with the required hold-down; http://publicecodes.cyberregs.com/st...0_6_sec002.htm
eg.---http://www.strongtie.com/search?v=hda%2Fhd%3Arelevance%3AproductType%3AHold ownZ
OR phd, hdu, hhdq, hda, hd-shearwall hold-down. What do the plans say?
Gary
Old 04-12-2016, 01:25 AM   #3
Registered User
Rewards Points: 526
http://www2.strongtie.com/software/i...ngwallselector
Gary
Sill lifting advice to satisfy anxious wife toddmanqa Building & Construction 6 12-23-2014 08:23 AM
Rim Joist inaccessible. darklightwarrio Insulation 10 01-13-2014 10:02 PM
Replacing rotted sill plate in 120 yr old home M.dizzle Building & Construction 16 02-29-2012 03:53 PM
How much Joist sitting on Sill plate? scott j Building & Construction 8 02-03-2010 11:00 AM
Fixing sill plate and rim joist undergrade TedF Building & Construction 5 05-21-2009 05:20 PM
