Rigid Foam Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-08-2009, 02:09 PM   #1
rigid foam insulation
Hello
I have read pages and pages here about using rigid form insulation for insulating my basement. If it matters I live in Connecticut.
My question is, is there a difference between the pink company and the blue company?
They both offer T&G or square edge, but the pink in over $5.00 cheaper per board. Both are 2 inches thick and offer r value of 10.
My question is one the blue brand that much better to pay 5.00 more per board?
Also what type of tape do I use to seal the seams where the boards meet?
Tom
ctkeebler is offline   Reply With Quote
Old 11-08-2009, 03:51 PM   #2
Remodeling Contractor
tape the joints and seal the edges and gaps with spray foam. extruded polystyrene (XPS) is the correct insulation to use.
Old 11-08-2009, 04:08 PM   #3
ccarlisle's Avatar
I think it matters a great deal where you are because most of us in the same zone are more familiar with our own building codes that the other codes...Look, I personally think they are equivalent, the blue being Dow's STYROFOAM board and the pink being Owens Corning's and I think there is a good reason they're different colours...differentiation.
At one time, Dow and Corning had a closer relationship than they do now. After the Dow Corning 'silicone' public relation nightmare, Dow distanced itself from the "Corning" name and presumably agreed to a deal that would allow Dow's technology to find an amiable "competitor". Enter Owens glass and hence Owens Corning. I'm probably way off the mark but I used to work for Dow Corning silicones (back in the day) when the breast implant scare came about. True or false, eveyone tried to disown Dow Corning without trashing their name. So Corning was sacrificed and the other divisions let to prosper.
So, I imagine it's "I'll make a pink one, you make a blue one" and we'll sell at the same price". But one will have deals on one week, the other the next...but the technology is the same, the marketing may be too, so it's six of one, half a dozen of the other, as they say.
The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,
ccarlisle is offline   Reply With Quote
Old 11-08-2009, 04:24 PM   #4
They are both XPS, the owens corning is available at the big orange store, the dow is at a local lumber yard. I try to support the local guy, but at 5.00 more per sheet and needing 20 sheets, that a big difference.
What type of glue do I use to attach the boards to the cement foundation and do I have to use other mechanical means?
Also if I frame the wall outside of the rigid foam insulation and they put up sheet rock, do I have to fill that void, between the foam insulation and the sheetrock?
Tom
Old 11-08-2009, 05:01 PM   #5
From what I've read, no you don't have to fill the void. But you can fill it with another insulation to bring up the R value since the rigid is usually rated 1"=R5. Just depends what R value you want, and how much $$$ you want to spend.
fubar79 is offline   Reply With Quote
Old 11-08-2009, 05:32 PM   #6
Rewards Points: 331
I might be remembering this wrong, but I believe it used to be said that the blue board acts as at least a partial vapor barrier. The pink stuff was reported to be vapor permeable. This would make a difference if moisture is an issue. The blue board also has a radiant insulating layer, which also can be useful.
dave11 is offline   Reply With Quote
Old 11-08-2009, 05:46 PM   #7
Dave,
I am not sure, but I copied this from the owens site" High-performance FOAMULAR 250 works to: Retard the transmission of water vapor
and moisture in masonry walls, helping prevent structural damage
I just have to make sure it does not come into contact with the hot water pipes that run in cavity between the sill plate the the concrete foundation.
Does anybody know how far away from hot water pipes. I understand it cannot come into contact, but is there a recommended or common sense distance.
"FOAMULAR insulation is ideal for all buildings under normal temperature
conditions, but should not be used in contact with chimneys, heater vents,
steam pipes or other surfaces where temperatures exceed 150 F. It is not
recommended for applications where sustained temperatures exceed 165 F.
Old 11-08-2009, 05:52 PM   #8
Rewards Points: 331
Originally Posted by ctkeebler View Post
Dave,
Yes, I think Foamular is a vapor retarder, but I also think the blue stuff is a vapor barrier, which is different. In other words, pink will slow down moisture but allow to pass, whereas blue will stop it altogether. This would be an issue if you were installing in areas where moisture needs to pass through, or where a vapor barrier was not allowed or recommended.
Old 11-08-2009, 05:59 PM   #9
in a basement you will want the water to move both in and out. No vapor barrier. Do not fill the void. This is used as an airspace to allow the wall to dry if it ever encounters a wet condition. Use kraft faced batt insulation in the stud wall. Residential heat pipes and water pipes do not get hot enough to harm this insulation. If you are concerned with it, then cut around the pipes and use fire retardant spray foam to seal these areas.
Old 11-08-2009, 07:03 PM   #10
Bob, are you saying use the Batts instead of the rigid foam? or use the pink foam as it allows the water to flow back and forth and fill the void with kraft faced insulation.
I just want to make sure its done right. My basement was finished when I bought the house, but discovered mold behind the sheet rock and the non pressure treated sill plates all rotted.
Old 11-08-2009, 08:28 PM   #11
Registered User
Rewards Points: 526
The blue and the pink are as ccarlisle said, same but different color. Both are rated at 1.1 permeability, a vapor retarder. This is what you want against the concrete wall. Neither one stops vapor as a vapor barrier.
http://www.dow.com/PublishedLiteratu...romPage=GetDoc
http://insulation.owenscorning.com/W...=id&ItemID=788
The unit of measurement typically used in characterizing the water vapor permeance of materials is the “perm.” Several classes of vapor retarders are further defined as follows [4]:
  • Class I Vapor Retarder: 0.1 perm or less
  • Class II Vapor Retarder: 1.0 perm or less and greater than 0.1 perm
  • Class III Vapor Retarder: 10 perm or less and greater than 1.0 perm
  • Test Procedure for vapor retarders: ASTM E-96 Test Method A (the desiccant method or dry cup method)
Finally, a vapor barrier is defined as:
  • Vapor Barrier: A Class I vapor retarder.
Materials can be separated into four general classes based on their permeance [4]:
  • Vapor impermeable: 0.1 perm or less
  • Vapor semi-impermeable: 1.0 perm or less and greater than 0.1 perm
  • Vapor semi-permeable: 10 perms or less and greater than 1.0 perm
  • Vapor permeable: greater than 10 perms From: http://www.buildingscience.com/docum...gs?full_view=1
Be safe, Gary
Old 11-08-2009, 09:00 PM   #12
Rewards Points: 331
Regarding the type of blue Dow product, I was assuming the original post was comparing pink and blue at the box stores, and here, the only blue board I've seen is Dow's Super Tuff-R, which has a perm rating less than 0.03, which makes it a vapor barrier.
Old 11-08-2009, 11:42 PM   #13
Registered User
Rewards Points: 526
" Both are 2 inches thick and offer r value of 10." In original post. So 1" would be R-5, the FOAMULAR 250, as in my sited reference. Not the foil and poly faced R-6.5, with the perm of .03 as you correctly stated. It can be confusing with a dozen different boards and applications from the same company:
http://building.dow.com/na/en/produc.../rigidfoam.htm
http://building.dow.com/na/en/produc...supertuffr.htm
Be safe, Gary
Old 11-09-2009, 04:03 AM   #14
I am saying to use the rigid against the foundation wall. It will keep the wall warm enough not to sweat. It acts as a capillary break, not as a vapor barrier. Then the 1/2"-1" air space. Then the wall. Between the stud spacing use kraft face insulation. You need to follow code requirements for R-Value once you finish the basement. The 2" foam is not enough R-Value. So you need both.
Old 11-09-2009, 07:08 AM   #15
Thanks for the clarification. Can I just cut the rigid into 15 inch wide pieces and put them into wall instead of using the batts? It may be more money, but I would be eliminating the possibility of mold growth correct?
The only issue I would see if trying to put the rigid where the electrical wires run. As the wires run about in the middle of the stud there would have to be alot of slack in the wire to run infront or behind the rigid foam board and Im not sure if that is even allowed.
It looks like R-11 is the lowest R value I can buy, plus the r-10 from the foam, puts me at a the upper limits of whats recommended R-21 in the cavity and R-19 recommended. I guess its better to have more than not enough? ( I live in Connecticut if that makes a difference or helps)
I
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Installing Rigid Foam Insulation and Drywall raheel Drywall & Plaster 3 02-16-2009 06:07 AM
Rigid foam sheathing on top of foam insulation? benjamincall HVAC 12 02-04-2009 12:41 AM
Using rigid foil faced foam insulation Ronnie1a Remodeling 1 01-22-2008 01:23 PM
