Replacing Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-15-2010, 06:05 PM   #1
Replacing windows
I am replacing my old wood Marvin windows. Sills are rotted so these are not replacement windows. I want to use the Marvin Integrity windows since I have them in my addition but the sizes are different. The new window is inch and a half shorter which I think I can work with. The width of the new window with the jamb extensions is the exact size of my rough opening. I was thinking I could cut out a jack and install 5/4 to gain some room. Any thoughts? Also plan on getting the pvc trim with the historic sill. 3 1/2" flat casing.
Richgvt is offline   Reply With Quote
Old 08-16-2010, 03:27 PM   #2
Rewards Points: 5,348
Reducing the header support could be problematic, especially on a load bearing wall.
Ron
Old 08-16-2010, 09:23 PM   #3
replacing windows
I spoke to a contractor who has replaced 2x jacks with 3/4 plywood. I might go with 5/4 instead. That would be plenty to support a header that is less than 3 feet wide.
Old 08-17-2010, 06:18 AM   #4
Tom Struble's Avatar
Rewards Points: 2,002
cool maybe you can find a contractor who will say to take out both jacks...give you even more room
Tom Struble is offline   Reply With Quote
Old 08-18-2010, 06:54 AM   #5
replacing windows
I am taking both jacks out.
Old 08-18-2010, 07:05 AM   #6
No guts, no glory.
Ron
Replacing Vinyl Windows w/o Nailing Fin irish Building & Construction 1 06-03-2010 10:37 AM
Replacing Windows? Kyle Remodeling 13 12-17-2009 07:03 PM
Replacing Windows (Which Brand?) dixieman Remodeling 3 04-30-2009 06:45 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
Replacing aluminum frame windows gallasm Remodeling 2 01-05-2009 10:03 AM
