Replacing Sill Plate Question - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Nealtw
  • 1 Post By ggano
Old 10-19-2017, 04:30 PM   #1
Rewards Points: 158
Replacing sill plate question
Because of past water damage I am replacing a 7' section of sill plate that is attached to the concrete slab at the front of the house. A few of the attached wall studs also have maybe 3" inches or so of water damage at the bottom where they attach to sill plate and are rotten. I know I need to use treated wood for the sill plate, but do I also need to use treated 2x4's that I will be sistering to the damaged studs? Just wondering. Tks.
ggano is offline   Reply With Quote
Old 10-19-2017, 04:41 PM   #2
retired framer
Rewards Points: 1,528
Re: Replacing sill plate question
Treated wood is fine but not needed. you do need to stop the water from getting in and stop water from wicking up from the concrete.
You can use a 4 x 6 and do both at the same time
Old 10-19-2017, 06:30 PM   #3
Rewards Points: 158
I forgot to ask the question re the wicking. Would this be just a strip of plastic between the wood and concrete? Any special thickness?
Old 10-19-2017, 06:36 PM   #4
retired framer
Sill gasket is a thin foam product, 6 mill poly will work.
https://www.lowes.com/pd/Dow-Sill-Se...t-L/1000172805
ggano likes this.
The Following User Says Thank You to Nealtw For This Useful Post:
ggano (10-19-2017)
Old 10-19-2017, 07:10 PM   #5
Rewards Points: 158
Thanks very much for the responses, appreciate it.
Nealtw likes this.
Old 10-19-2017, 08:14 PM   #6
Rewards Points: 158
Related question before I go. I will be framing an interior wall for a bedroom closet. Is a barrier such as this also necessary for the sill plate on an interior wall constructed over concrete? Tks.
Sill plate repair Dbonawitt Building & Construction 1 07-12-2016 11:08 PM
Sill plate attachment to foundation WillK Building & Construction 3 10-12-2015 02:28 PM
Foundation anchor bolts and sill plate question dwoloz Building & Construction 7 05-17-2011 08:17 AM
Replacing Section of Sole Plate RM575 Carpentry 3 03-28-2010 10:31 AM
Sill plate and rim joist question bhasty Building & Construction 3 10-15-2009 03:07 PM
