Replacing Rails On A Deck With A Roof. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-22-2019, 06:50 PM   #1
Rewards Points: 72
Replacing rails on a deck with a roof.
Iím about to do an overhaul on a deck. The deck seems like the old owner had it screened in. And the railing is spaced 3í from one another...
The goal is to get away from the screened in look and make a beautiful railing with it with traditional Balibusters...
It looks like they built that roof for the deck by building the new roof over the existing roof. They are using 2x6 (Iíll recheck in the morning) and itís spannning roughly 10 feet...
A. Iím going to have to knock some out to start building my new rail. Whatís the max safe span I should keep in order to keep the entire roof from collapsing?
B. Instead of having a post every 3 feet that runs to the ceiling. Whatís the max span I can have before I need another post? Prob going to use 4x4
This is what we built for the back yard. Going for this look except the post will run up to the ceiling
NGLogik is offline   Reply With Quote
Old 01-22-2019, 07:00 PM   #2
retired framer
Rewards Points: 18,388
Re: Replacing rails on a deck with a roof.
You are changing it from wall to post and beam, The posts will be 6x6 and the beam length and size depends on loads.
Like you last picture, your fence post are above a pier down to the ground.
Your new roof posts will also need support right to the ground, If you have that now the distance apart will dictate the size of the beam.
Old 01-22-2019, 07:13 PM   #3
retired framer
Your posts may not be out at the edge of the deck.
Deck over roof --Help, I need product to repair roof w/o deck tearoff jaes Roofing/Siding 5 08-09-2017 04:34 PM
Is it safe to build a roof over my Hawai'i deck? ModelM2HB Building & Construction 11 07-03-2012 06:22 PM
Roof over Deck Ideas? drekce Building & Construction 8 07-02-2012 09:15 PM
Deciding on replacing deck or enclosing maj0819 Building & Construction 4 03-23-2011 02:43 PM
flat roof under deck??? Jeremy Hillary Boob, PhD Roofing/Siding 3 05-05-2009 07:20 AM
