Replacing Rafters On Ridge Beam Barn - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-21-2014, 04:10 PM   #1
Replacing rafters on ridge beam barn
I have a 32' x 40' old pole building. I'm replacing the top half. I need a 24' rafter to reach outside walls to ridge beam.
I was going to laminate 4 -12' x2"x6" using adhesive and screws every 6". Will this be sturdy enough? 4/12 pitch
Get nailed is offline   Reply With Quote
Old 07-21-2014, 04:39 PM   #2
Rewards Points: 2,620
Since you only need one rafter it will probably work. But before you choose an adhesive do a shear test with an adhesive and glue to determine which you would consider the strongest.
Old 07-21-2014, 04:44 PM   #3
What if I need to replace all of them. 40 to ne exact.
Old 07-21-2014, 04:52 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 6,712
This is definitely a questions for a qualified engineer.
Old 07-21-2014, 05:06 PM   #5
I don't know why you would need 40 but if going that route definitely buy truss rafters.
Old 07-21-2014, 05:10 PM   #6
20 each side. I contacted an engineer to see . Thanks for the help.
Old 07-21-2014, 06:32 PM   #7
Framing Contractor
Rewards Points: 76
That is not gonna work. No engineer will even consider that. Consider using pre made roof trusses. You could even gain a loft by using attic trusses.
sixeightten is offline   Reply With Quote
Old 07-22-2014, 06:19 AM   #8
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Single 2x8's will span that.
tinner666 is offline   Reply With Quote
Old 07-22-2014, 11:19 AM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 96
Your rafters are not 24 feet long, spanning 16 feet with 4/12 pitch is only about 17 feet.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 07-22-2014, 11:22 AM   #10
I'm allowing for a 2-1/2 foot over hang.
Old 07-22-2014, 11:26 AM   #11
A "Handy Husband"
rjniles's Avatar
Rewards Points: 96
That is still under 20 feet
Old 07-22-2014, 11:37 AM   #12
I was just allowing for cuts and defects in the wood. Suchs as splits ,knots,
I spoke to a local lumber yard that make trusses and rafters. After explaining to them my problem they suggested using 1-16' with 2 -12' 2x6's usiing cross bracing as well as steel plates at seams.
Old 07-22-2014, 11:49 AM   #13
A "Handy Husband"
rjniles's Avatar
Rewards Points: 96
I would talk to them about using trusses. You building inspector may want an engineer to approve the use of regular rafters with splices.
Old 07-22-2014, 12:06 PM   #14
I suspect the roof failed because of this type of construction. Consider 10 trusses on 4 ft. centers with a steel roof.
Old 07-22-2014, 12:07 PM   #15
Well this is Wv and no inspections just permits required.
They feel as long as the splice isn't in or near center it should be ok. I will try to contact a nuilding engineer before I do anything.
This project is a 50 plus year old stone foundation with a 4x10 chestnut ridge beam. There were 4x6 pine rafters every 4 ft. I want to place them 2 ft on ceenter.
Ridgevent solution for a wide ridge beam daveskee Roofing/Siding 12 12-02-2010 10:13 AM
Ridge Beam mikec205 Building & Construction 4 10-16-2010 04:37 PM
gap between ridge beam and ridge board mdudu Building & Construction 6 05-07-2010 09:46 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 06:47 PM
ridge beam rakuz66 Building & Construction 8 07-29-2008 01:01 AM
