Replacing Old Siding Panels - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-21-2010, 02:44 AM   #1
Replacing old siding panels
Does anyone have any ideas how I can best fix these two problem areas with the siding. I have not been able to find any siding that matches these exactly, the siding is probably from the 60's. I am selling the house to a buyer with an FHA loan and this must be fixed to complete the sale. Thanks for any help.
giappino is offline   Reply With Quote
Old 11-21-2010, 03:57 PM   #2
Rewards Points: 5,348
What material are these panel made from? Are these the asphalt impregnated fiberboard with a granular surface?
Ron
Old 11-21-2010, 04:05 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,480
Ayuh,... Probably the cleanest, easiest, cheapest fix would be to tastefully cover over that with another type of material,...
Contrasting color flashing maybe,..??
You might salvage some of the lower material that's there to fix some of the higher up stuff, to in effect lower the new border area...
Old 11-21-2010, 04:25 PM   #4
kwikfishron's Avatar
Rewards Points: 864
Ron
I think you are correct, looks kind of like this stuff.
kwikfishron is online now   Reply With Quote
Old 11-22-2010, 11:35 PM   #5
Insulbrick
It is called Insulbrick, some people call it ghetto brick. It is a 2x4 panel, I'd like to buy some replacement pieces that would fit neatly in there. Does anyone know where I can find some Insulbrick?
Old 11-23-2010, 07:39 AM   #6
It is very doubtful there are any companies making this product anymore.
Ron
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Replacing Wood Siding WIth Foam Backed Vinyl xludan Building & Construction 1 05-21-2009 06:27 PM
Replacing Wood Panel 4'x8' Siding Chevmann99 General DIY Discussions 5 10-02-2005 07:43 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
