Repairing Concrete Steps - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-30-2015, 02:29 PM   #1
Rewards Points: 340
repairing concrete steps
Will some kwick crete topping mix stick on the lower part until i can
jackhammer the whole thing out ? I will do some prep
kt82 is offline   Reply With Quote
Old 08-30-2015, 02:52 PM   #2
Rewards Points: 5,348
Are you talking about one step? By the time you do a half assed repair you can pull out the step, form it with 2x4's and pour a new one.
With all the supplies, it's a four hour job.
No, the repair you offer won't work. I don't think any will.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
kt82 (08-30-2015)
Old 08-30-2015, 09:14 PM   #3
Rewards Points: 2,264
If it is a pre-cast step that was bought and set in place you can break it apart with a sledge hammer usually.
A poured in place built on site step may take a jack hammer.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
kt82 (08-30-2015)
Old 08-30-2015, 10:17 PM   #4
Rewards Points: 340
great example of pre·science (the fact of knowing something before it takes place; foreknowledge.)
while i was at lunch on they way to fix the step I got a call that one of the renters had broken thru the step of a precast unit at another unit
if things didn't fall apart I would be out of a job!
The Following User Says Thank You to kt82 For This Useful Post:
mae-ling (09-19-2015)
Concrete Steps Coating marcos.cristal Concrete, Stone & Masonry 1 05-06-2015 06:12 PM
Home entry concrete steps and iron railing problem. sukhenkoi Concrete, Stone & Masonry 16 05-20-2014 07:54 AM
Adding to Concrete Porch + Steps? 99altrade Building & Construction 8 08-01-2011 01:14 PM
Rebuild concrete steps leading to basement gruntman Building & Construction 32 09-30-2009 12:55 PM
forms for semi-circular concrete steps cirsteps Building & Construction 7 10-23-2008 12:22 AM
