Removing Wall Under A Load Bearing Beam. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-04-2010, 07:22 AM   #1
Removing wall under a load bearing beam.
Hi all.
I'm looking to remove the wall below the beam in the attached photos. There are 4x4 posts on both ends supporting the beam. This is an interior wall, the right side adjacent to an exterior wall. Also, this wall is on the first floor of my 2 story house. Can I safely remove the 2x4 framing and the parallel 2x4 directly below the beam?
Thank you!
Joezer is offline   Reply With Quote
Old 12-04-2010, 07:35 AM   #2
Chicago, IL
Michael Thomas's Avatar
Everything else aside, that diagonal brace my be there for a specific structural propose. Do you have the original plans? Do they specify the brace?
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 12-04-2010, 07:53 AM   #3
Unfortunately, I don't have the original plans. The wall is running north and south. I live in Southern California. I believe the brace is for sheer... wind or quakes... maybe.
Also I forgot to add that the adjacent exterior wall on the right side is now an interior wall. There was a addition a single story room addition added long ago. So I believe that would possibly negate need for that brace.
Lastly, I will be adding sheer brace on a parallel exterior wall I will be closing up after removing a patio door.
Old 12-04-2010, 03:17 PM   #4
You can hide the whole beam in the ceiling if you know what you're doing. Is there any reason you just want to remove the studs? You'd still have to replace the beam with a sturdier one
mrgins is offline   Reply With Quote
Old 12-04-2010, 05:27 PM   #5
Right, I'm removing all of the 2x4 studs. I'm leaving the beam in place. Do you think I need a sturdier beam?
Old 12-04-2010, 05:59 PM   #6
Framing Contractor
How can anyone possibly answer this because no one including yourself knows what this beam is supporting above?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 12-04-2010, 06:01 PM   #7
kwikfishron's Avatar
Rewards Points: 826
Between the let in brace and all of the electrical drilled up through the beam nobody here or on any other website can answer your question. You need to have a Structural Engineer look at it.
kwikfishron is online now   Reply With Quote
Old 12-04-2010, 07:26 PM   #8
Thanks for the replies.
Old 12-04-2010, 07:54 PM   #9
Did you really read anyone's response?
Old 12-04-2010, 09:33 PM   #10
Of course I did. I'm going with the advice of seeking a structural engineer. Since, it's the only way I can get a definitive answer.
Old 12-04-2010, 09:49 PM   #11
Woodtick
Joe, KFRon and Joe Carola are right. You need to consult a structural engineer before you tear into that wall.
ccnvchris is offline   Reply With Quote
Old 12-04-2010, 09:51 PM   #12
Anyone know of a good structural engineer in Woodland Hills, CA?
Thanks for the advice.
Old 12-05-2010, 10:30 AM   #13
OK. Good
Old 12-05-2010, 10:37 AM   #14
Rewards Points: 121
You might try a large local building supplier. Here they offer that service. Not sure they are employees of the supplier or just engineers they know, but it might be a good place to start.
JoeLena is offline   Reply With Quote
Old 12-05-2010, 11:36 AM   #15
Jeozer,
I also live is So. Cal.. When I added a patio cover to my house I went to the city and talked to the engineer in planning. He helped me with load calculations and lumber sizing. You may want to start with your city planning department.
NASCAR9 is offline   Reply With Quote
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 04:33 PM
Metal Stud Top Plate onto I Beam for NON Load Bearing Wall jdm001 Building & Construction 2 06-24-2010 10:31 AM
Removing part of load bearing wall? destroyer427 Building & Construction 11 04-08-2009 02:24 PM
Load Bearing Wall rpatterson Building & Construction 2 10-29-2005 07:43 AM
