Removing Wall In Home - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-15-2009, 07:33 PM   #16
Phil
You will probably want to get permits and do this legally so it depends on what the local building department people decide is required. Worth checking it out before you get started. More than once I have had contractors say that something was fine only to have to make expensive alterations after the inspector came by.
Phillysun is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
How to make wall smooth after removing tile? cheapchick Remodeling 20 04-09-2012 01:59 PM
Exterior Brick Wall Seperated from Home mrhonest Building & Construction 3 01-15-2009 05:06 PM
Removing load bearing wall jjbarnes911 Remodeling 6 01-08-2009 09:32 PM
Help !!! Removing A Wall slinkey Remodeling 1 09-16-2007 10:35 PM
