Removing Soffit To Replace Sheathing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-03-2011, 05:33 PM   #1
Rewards Points: 524
Removing soffit to replace sheathing
I'm in the process of replacing eight feet of wall sheathing. Under my aluminum soffit panels is a plywood soffit.
Should I rip the plywood out of there so that my new sheathing will extend all the way up to the top plate?
benjamincall is offline   Reply With Quote
Old 01-03-2011, 05:34 PM   #2
Framing Contractor
Is the sheathing rotted? Why are you replacing it?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 01-03-2011, 05:41 PM   #3
Rewards Points: 524
Wow, fast reply. The sheathing is cedar lap siding. I already purchased zip system osb panels for the whole house.
I wanted OSB panels to provide a smooth surface for the fiber cement siding that I'll eventually install. I also like the wrb coating on the zip panels.
I guess I have to rip out the soffit, right?
Old 01-03-2011, 09:05 PM   #4
Registered User
Rewards Points: 526
Did you research the AdvanTech at all?
Gary
Old 01-03-2011, 11:22 PM   #5
Rewards Points: 524
Gary,
I'm not sure the AdvanTech Sheathing product was available when I purchased the Zip System stuff. Advantech is great for its structural properties, but I still like the integrated WRB so I can do my piecemeal siding work without having house wrap flapping in the wind.
To my original question:
I can see no option but to destroy the soffit.
removing wall that soffit was attached to Lizybizy Building & Construction 3 05-27-2010 04:48 PM
exterior sheathing - keep it or replace it? derf36 Building & Construction 12 08-04-2009 11:19 PM
Sheathing versus Winter Weather Rusnakes Building & Construction 2 07-11-2009 06:17 PM
Vinyl Soffit man117 Building & Construction 4 11-11-2008 06:53 PM
Removing ductwork in soffit... inovermyhead HVAC 2 04-02-2006 11:56 PM
