Removing An Old Elevator With Balancing Weights - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-31-2016, 06:38 PM   #1
Removing an old elevator with balancing weights
I know this post is old, but I'm in need of some help. I have an elevator I have been asked to remove and I'm not worried about the removal, I'm worried about the stacks of weights on the other end of the chains. One end of the chains are connected to the elevator box, the other has a ton of weights on it. So when I think about it, if I cut the weights off the box's come crashing down, if I cut the chain off the box the weights come down? Ant order in how I should do this? I'm very mechanically cline, I just need like a step process so I don't end up hurt or dead. Haha any help would be great thanks
jimvanderwater is offline   Reply With Quote
Old 03-31-2016, 06:39 PM   #2
Re: Elevator removal structural fun
Originally Posted by oh'mike View Post
Usually the floor is just reframed for an opening--then a support member (usually a lam-beam) is attached for the carriage--then standard framing for the walls--Well in the floor for the bottom of the cage--
Not any special skills needed to remove----Take it away!!
My mother used to wish for a hinged floor in our bedroom --so she could just pull a leaver and every thing in the room would just drop to the basement--
This might be the chance to build a self cleaning kids room-Just a thought.
Can you help with my post?
The Following User Says Thank You to jimvanderwater For This Useful Post:
oh'mike (03-31-2016)
Old 03-31-2016, 06:40 PM   #3
Also forgot to say, the owner said that the rails on the walls can stay.
Old 03-31-2016, 08:06 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 30,982
You need to lower one or the other, weights or box. Box is probably easier. Then attach a winch to the cables. Cut cable free from box and lower weights with winch.
Old 03-31-2016, 08:42 PM   #5
Civil Engineer
Rewards Points: 5,246
Seriously, you plan to take on what by your description is a life threatening project if done incorrectly. And you seek help from an internet chat room? This vaguely reminds me of the post about dynamiting a basement, and looking for assistance in how to place the charges....
The Following 3 Users Say Thank You to Daniel Holzman For This Useful Post:
dd57chevy (04-02-2016), gregzoll (04-02-2016), oh'mike (03-31-2016)
Old 03-31-2016, 10:49 PM   #6
Retired Moderator
Rewards Points: 7,174
I've never worked on an elevator with weights---
How tall is tha shaft? how much heat space above the cage?
Old 03-31-2016, 10:56 PM   #7
Retired Moderator
re: Removing an old elevator with balancing weights
I made this into its own thread.
Let's see if anyone else has any experience with this job.
Do you have any pictures of the weights? Can the box be lowered to the bottom of the shaft and then remove the weights a few at a time?
Old 04-02-2016, 08:48 AM   #8
JUSTA MEMBER
Rewards Points: 2,338
Re: Removing an old elevator with balancing weights
In my understanding of elevator systems, both the car and the counterbalance should both have a locking mechanism to keep either one from falling to the bottom of the shaft in the event of a failure.
So look them over, then lock the weights at the top, and start disassembling the weights one by one and trudging them downstairs.
Then lower the Chain down with a winch to the car, and disassemble it.
just be careful, as these things are dangerous, you have an open shaft, you should have a lot of weight overhead.
ED
de-nagorg is online now   Reply With Quote
Old 04-02-2016, 01:39 PM   #9
Rewards Points: 258
how many floors are you talking? height from top to bottom?
woodchopper65 is offline   Reply With Quote
Old 04-02-2016, 04:23 PM   #10
Plumber
TheEplumber's Avatar
Rewards Points: 1,040
Disrespectful posts removed
Please read updated Forum rules
http://www.diychatroom.com/f2/announcements/
Old 04-02-2016, 04:37 PM   #11
Rewards Points: 144
I don't think my post was disrespectful.I thought the Op's post was disrespectful to a member of the forum that is very helpful and knowledgeable.It hit a nerve with me and I replied in a decent manner .I thought.
Of course you are the mod and I respect your opinion also.Sorry for any inconvenience to you.
mako1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mako1 For This Useful Post:
gregzoll (04-02-2016), TheEplumber (04-02-2016)
Old 04-02-2016, 06:49 PM   #12
The post from Daniel Holzman is the post that was disrespectful, yet you delete mine? What kind of forum do you run here? So I can ask a question or for help and someone can come on here and disrespect me for my question? Seriously? I think the mods here need to look into things before they react. I guess we can just get on a post and make them feel horrible because they ask a question......
Old 04-02-2016, 07:14 PM   #13
kwikfishron's Avatar
Rewards Points: 236
One that speaks the truth (most of the time). In your case you received spot on advise. Sorry if that isn't what you wanted to hear.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 04-02-2016, 07:18 PM   #14
Rewards Points: 4,446
LMAO - hell, driving down the road is life threatening even if you do it correctly. Go for it when you get it analyzed how.
I don't have any advise without seeing it but I will say a counter balance can be water and that can easily be adjusted as needed.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
jimvanderwater (04-10-2016)
Old 04-02-2016, 07:20 PM   #15
Rewards Points: 380
WWHHHHHAAAAATTTTT???
You must find that post and share it! OMG, the things people will attempt!!
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
The Following User Says Thank You to dougp23 For This Useful Post:
Removing wall mount sink connector OldHomeJen Plumbing 6 11-27-2013 08:45 AM
Antique Double-Hung Windows Missing Pulley Weights TOTALN00B Windows and Doors 19 08-15-2011 05:46 AM
Removing tile; electric tile stripper or rotary hammer? mackaz Flooring 0 07-21-2011 06:22 PM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 10:49 AM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 09:28 AM
