REmoving Interior Chimney Breast. Supporting Chimney Stack Above - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-23-2009, 03:03 AM   #1
REmoving interior chimney breast. Supporting chimney stack above
hello All,
We've about to move into a terraced house and would like to take the chimney breast out on Ground and 1st Floor, pinning the breast/stack in the loft. Could anyone recommend:
A. The Certified Board to which the builder should belong?
B. A Surveyor (North West England)
C. Who to go to for Buildings Insurance (for an effective quote) even before work starts?
D. Any other comments, experiences, anecdotes or info you may think useful.
Thank you for any thoughts/advice!
Si
sieck is offline   Reply With Quote
Old 12-23-2009, 06:08 AM   #2
Rewards Points: 582
As this is structural work you need to go through Building Control at your LA.
The calcs will need to be done by an S/E, not a surveyor.
The builder you employ should have his own insurance.
There is also the Party Wall Act to think about if the stack is tied into the party wall.
Years ago you could knock them down and just corbel the brickwork into the party wall, but nowadays Gallows brackets or RSJs are used.
There is a lot of brickwork in the old chimney breasts and it is a dusty job, but the work involved in the support doesn't take long.
stuart45 is offline   Reply With Quote
Old 12-24-2009, 02:27 AM   #3
Thank you very much Stuart. More than helpful!
Has anyone any North West England based firms they'd recommend for taking out a chimney breast; profesional, insured etc (?)
Any advice appreciated.
Simon
Damp Patch Chimney Breast Mark_84 Roofing/Siding 3 10-16-2008 03:52 PM
removing stack with snap cutters drewhart Plumbing 1 07-18-2008 03:00 PM
What to expect in removing a chimney? pcampbell Building & Construction 2 03-09-2008 08:54 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
chimney stack removal davedish Building & Construction 9 02-22-2007 08:07 PM
