Removing Collar Ties - Plywood Gussets ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-11-2010, 09:33 AM   #1
Removing collar ties - Plywood gussets ?
Originally Posted by AtlanticWBConst. View Post
If they are there, then there is a reason for it...(example: the ridge beam and rafters sound undersized and this was a way of compensating)
Solution:
1.) Add knee wall framing and collar ties to each side (sandwiching) the rafters at a higher location.
or
2.) Create plywood gussets and install them at a higher location on EACH rafter.
Do not move them so far up that you defeat the purpose of the collar ties...
MOST IMPORTANTLY:
I would recommend that you have someone knowledgable, view the rafter layout on site to see if there are other structural areas that could be affected ... BEFORE you start to do anything up there.
I've seen a few people mention replacing the ties with plywood gussets. My question is how big do they have to be(ridge to bottom of triangle)? Also guessing it needs 3/4" plywood??? Anyone have a pic of the plywood gussets? thanks
jmcfall is offline   Reply With Quote
Old 03-11-2010, 10:46 AM   #2
http://images.google.com/images?q=pl...N&hl=en&tab=wi
cellophane is offline   Reply With Quote
Old 03-11-2010, 10:53 AM   #3
Rewards Points: 151
I just did this with approval by the Building Inspector. I did need to get an engineer to evaluate the plan first. The plywood gussets, the bottom came to the top of the collar ties so I gain close to 6". They were made with 3/4" structural plywood and need to be sandwiched on each side of the rafters. I used construction adhesive and nails. Worked well.
gregt848 is online now   Reply With Quote
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 07:06 PM
Removing kitchen tile with plywood under it ediconu Flooring 4 08-26-2007 08:48 PM
collar ties explained? troycalm Carpentry 13 04-04-2007 02:16 PM
Roof Sagging wall bowing christy123 Carpentry 37 12-29-2006 04:16 PM
Removing Collar ties Mike2004 Building & Construction 6 12-16-2006 01:48 PM
