Remove Existing Chimney - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-04-2009, 02:47 PM   #1
Power Gen/RS Engineer
Rewards Points: 566
Remove existing chimney
Greetings y'all-
I'm not too sure if this is more appropriate as an HVAC question but it seems relevant to general construction...
I have an existing brick chimney that extends from the basement to the roofline whose sole purpose is for venting the gas hot water heater and gas-fired boiler in my basement. The problem is, this chimney runs through both 1st and 2nd floor bathrooms and occupies precious space in both immediately adjacent to the toilets. Since I am in the process of redesigning both, I am curious as to the following:
If I remove the chimney, can the venting be acheived via a new sheet metal vent (from basement to roof) with enclosing it in brick again? If so, where could I find a source for design/sizing/installation details/codes?
Thanks!
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 07-04-2009, 05:21 PM   #2
Chicago, IL
Michael Thomas's Avatar
Originally Posted by BigJimmy View Post
Where could I find a source for design/sizing/installation details/codes?
www.duravent.com/pdf/shbook.pdf
Home Inspection: "A business with illogically high liability, slim profit margins and limited economies of scale. An incredibly diverse, multi-disciplined consulting service, delivered under difficult in-field circumstances, before a hostile audience in an impossibly short time frame, requiring the production of an extraordinarily detailed technical report, almost instantly, without benefit of research facilities or resources." - Alan Carson
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Chimney Confusion (Long) wehcyar Building & Construction 10 02-12-2017 06:16 AM
water damage remove mold & repair or replace drywall homerepair1 Drywall & Plaster 2 02-22-2009 10:00 AM
Adding stone to existing brick chimney TVC15 Building & Construction 5 08-13-2008 05:19 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
Addition around existing brick chimney Adenmoor Building & Construction 2 11-20-2004 10:37 PM
