Remove Bearing Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By Guap0_
  • 1 Post By Nealtw
  • 1 Post By Yamvmax
  • 1 Post By carpdad
Old 02-06-2018, 04:56 AM   #1
Rewards Points: 31
remove bearing wall
Removing 11 feet of a bearing wall on a slab foundation. Above is 2x8 spanning 16 feet from one end of the outside wall of house. On other side of bearing wall are ceiling joists running same direction of bearing wall 12 feet that sit on other outside wall, then are attached to a double 2x8 header that also sits on the bearing wall I am removing. I am NOT removing that part that holds up the 2x8 header. So in reality only part of wall I am removing holds up the one side of ceiling joists. I want install an LVL in place of the wall. Its 11'. Instead of building temp wall, can I "hang the ceiling joists temporarily from the 2x10 rafters above? I would use 2x4 nailed to each one. This would be just until I place the LVL, and attach the ceiling joists to that.
Yamvmax is offline   Reply With Quote
Old 02-06-2018, 08:40 AM   #2
Guapo
Rewards Points: 11,950
Re: remove bearing wall
What do you have against building a temp wall? I wouldn't take the chance.
Nealtw likes this.
Guap0_ is offline   Reply With Quote
Old 02-06-2018, 08:58 AM   #3
Rewards Points: 31
Your right, was just trying to avoid damaging the sheetrock where temp wall would go up. Kind of dumb. I will just build the temp wall, and be safe. What I am wondering though is if I can just hang the one end of the lvl onto the 2x8 header that carries the load of the ceiling joists running perpendicular to the other ceiling joists? Ceiling joists are just carrying load of ceiling.
Old 02-06-2018, 09:06 AM   #4
retired framer
Rewards Points: 6,362
You are asking questions that require math. Live and dead loads, spans and point loads as well as footing questions. The best you get is guessing here, some lumberyards will help you figure out what you need but really if you drawer up for a permit, they may tell what needs to be increased or send you to an engineer.
mae-ling likes this.
Old 02-20-2018, 11:16 AM   #5
Rewards Points: 31
Project done! Lvl sitting on top of double 2x4's on each end.
remove bearing wall-20180219_125457.jpg   remove bearing wall-20180219_193440.jpg
Nealtw likes this.
Old 02-22-2018, 08:43 AM   #6
Rewards Points: 558
This is late but are there footers under the header posts? Or a beam rated for new load points?
Nealtw likes this.
carpdad is offline   Reply With Quote
Create door opening in load bearing wall ggano Building & Construction 10 08-08-2017 03:23 PM
remove 20ft Load bearing wall in basmeent. xclaim Building & Construction 9 01-13-2015 06:27 PM
Load Bearing wall or not? Dennis6950 Remodeling 5 02-01-2011 09:34 PM
Is this wall bearing? adamgram Building & Construction 15 01-18-2011 10:32 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 04:44 PM
