Regular Tape For Backerboard? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 05:19 PM   #1
Rewards Points: 288
regular tape for backerboard?
I saw a product advertised for taping seams in concrete backerboard - alkali resistant. I haven't seen this sold anywhere around here.
Is this overkill? Can I use just a regular fiberglass tape to mud the seams in the backerboard?
thanks
rtoni is offline   Reply With Quote
Old 11-29-2010, 05:23 PM   #2
If you have a problem, do you want the warranty to stand up for the backerboard? It's not that expensive
mrgins is offline   Reply With Quote
Old 11-29-2010, 05:44 PM   #3
Rewards Points: 288
I haven't seen it in any box stores or building supply stores around here - otherwise I would just grab a roll.
Old 11-29-2010, 05:56 PM   #4
Oh, sorry! Is there a home depot or lowes near you? Or any trowel trades store?
Old 12-01-2010, 12:14 PM   #5
Rewards Points: 288
no worries - appreciate the feedback. We have a HD here but that's one of the places I couldn't find anything other than the standard f/g mesh tapes. also did a quick look thru a couple of the lumber yards where I usually get stuff. I haven't done an exhaustive search but I assumed anyone who sells drywall or backerboard would also carry the necessary parts.
I might call one of the tile stores and see if they can help out - they must buy this stuff from somewhere.
Old 12-01-2010, 12:30 PM   #6
Electrician
Home Depot should have it.
I noticed that it doesn't mention alkali, either do the screws even tho they are specifically for cement board.
VersaBar is offline   Reply With Quote
Old 12-01-2010, 12:34 PM   #7
What's an electrician doing answering this? Just kidding! I've bought it from HD. I also buy the screws that are manufactured by the backer board company.
Old 12-06-2010, 12:31 PM   #8
Rewards Points: 288
I found the durock screws at another store (also could not locate these at the HD here - silly me actually looking in the shelves where they sell screws). Turns out they do carry a "kit" for cement board - nowhere near the cement board or the screws - 100 screws and a roll of mesh tape packaged together - something like $20. I have to assume the tape is made for this application and not just a standard roll 'cause I can't see any difference looking at it. Feeling kinda srewed since I have to spend $20 to get 20 or 30 ' of mesh tape (enough to do my job). Guess the extra unnecessary "screws" in the package are kinda symbolic...
Old 12-06-2010, 12:45 PM   #9
SteelToes's Avatar
Rewards Points: 150
Hey rtoni my name is George and i work for a Chicago are Home Depot.
HD does carry a cement board tape and something that is called a RockOn screws.
Tape and screws should be located in our drywall aisle ...
SteelToes is offline   Reply With Quote
Old 12-06-2010, 01:01 PM   #10
Rewards Points: 288
Hey George - thanks for the reply. I've been up and down the isles - I will likely be back in there again this week (unrelated items) so I can sanity check but so far all I see are the durock "kits" that I mentioned (btw - this HD is in Canada - not sure if that makes a huge difference in what types of product are stocked in that area...?)
thanks
Old 01-04-2011, 04:57 PM   #11
Rewards Points: 288
just an update fwiw - tried HD (again) plus TimBrMart and 2 other local lumber yards - nobody had this tape / product. Last stop was a Rona / Cashway on the far side of town - they had it in stock and on the shelf. The guy there knew exactly what I was talking about.
Interesting that they all carry the same backerboard brand but only 1 knew anything about the alkali resistant tape (made by the same manufacturer).
Old 01-04-2011, 08:44 PM   #12
Rewards Points: 2,470
rtoni,
I got the tape in the home despot aisle where the thinset mixes and other floor/wall tile tools and mixes were located. I bought a huge roll for a 3 x 5 powder room floor (about 2' of it used!) but didn't want to risk the floor failing. It hasn't and I haven't looked back.
bob22 is offline   Reply With Quote
Paint problems....or just problems with the painter... deanswife Painting 5 07-30-2010 09:36 AM
Frozen Hot Water Pipes TravisW Plumbing 11 12-10-2009 06:26 PM
Regular duct tape for bathroom exhaust? dtran HVAC 1 10-27-2009 04:26 AM
Masking and Blue tape ripping off paint LeviDIY Painting 20 10-21-2009 07:56 PM
Regular Foil Ducting Tape handy man88 HVAC 7 07-17-2009 04:39 PM
