Redo Foundation With Structure On Top - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-23-2014, 09:09 AM   #1
hohadcr's Avatar
Rewards Points: 452
Question
redo foundation with structure on top
I have a garage approx. 30X50ft. used to park 3 cars. Now in disrepair. The garage is on a slab, or dirt, with no foundation right now.
I need to add a foundation to it, a foundation that will support 3 storeys in the near future.
Problem is that I cannot take the garage down to do the foundation. I have to keep at least 50% of the structure at any time or I lose my right to build.
How do I keep the half structure while digging and adding foundation?
I have seen houses sorta lifted up while adding or repairing foundation. The garage does not have a proper floor that I can lift on tho. ...
hohadcr is offline   Reply With Quote
Old 09-23-2014, 12:29 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 30,184
Does it have trusses or ceiling joists? Build a support wall 2 feet inside the existing wall to support the roof. The wall will hang in mid air. Dig under the wall and install new foundation. Do one wall at a time.
Or do the support wall thing and do each corner 5-6 feet in each direction. Then do the wall sections in between using the corners to support the structure.
The Following User Says Thank You to joed For This Useful Post:
stadry (09-27-2014)
Old 09-23-2014, 12:32 PM   #3
Rewards Points: 144
I understand this is a DIY forum but you need to hire a pro to do this.Probably an engineer too.Especially if you need to get permits.Not familiar with the codes in Canada.
mako1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mako1 For This Useful Post:
joecaption (10-04-2014), stadry (09-27-2014)
Old 10-03-2014, 10:54 PM   #4
hohadcr's Avatar
Rewards Points: 452
So,I will pour foundation one section at a time, and use rebar to connect them?
Thanks!
Old 10-04-2014, 08:18 AM   #5
Super Moderator
joed's Avatar
Thanks!
That is the basic idea, yes.
Old 10-04-2014, 08:22 AM   #6
Rewards Points: 18,244
Opening up a whole can of worms by wanting to add two more story's.
Need an engineer to come up with some plans and drawings.
Just going to end up with a weak foundation trying to do this in sections.
Old 10-10-2014, 11:26 AM   #7
hohadcr's Avatar
Rewards Points: 452
Hi, joe captain,
Yes, i understand that it needs engineering. Im just trying to plan for the physical work. I'm very shy in paying the foundation guys 10-20k a week, and for unknown no.of weeks... this seems to be the universal quotes here for foundation work.
Thus I'm planning on driving the back holes myself...
Old 10-10-2014, 06:48 PM   #8
Super Moderator
joed's Avatar
If it is engineered properly supports can installed inside the structure to allow the entire foundation to replaced at once.
Old 10-11-2014, 08:53 PM   #9
Knucklez's Avatar
Rewards Points: 1,002
yep that's the way. real pros will suport entire structure and may even lift a bit while they install entire monolithic slab according to engineered plan. i'm a crazy DIY'er doing projects most wouldn't. i wouldn't touch this one.
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 10-12-2014, 08:47 AM   #10
Super Moderator
joed's Avatar
This one should be rather simple to support. If I remember this is only a light garage.
hohadcr (10-25-2014)
How to stub off an old stone and mortar foundation beautah Concrete, Stone & Masonry 0 04-25-2012 10:43 AM
frost protected shallow foundation retrofit for 100+ year old limestone foundation degnem Building & Construction 7 06-24-2010 07:33 PM
prefab, min/no foundation structure??? shabba1985 Building & Construction 12 06-18-2010 05:53 AM
mulch against foundation??? fabian Landscaping & Lawn Care 2 05-08-2009 10:38 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
