Rebuilding A Bridge - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-20-2010, 01:37 PM   #1
rebuilding a bridge
The old bridge is 2 telephone poles that are badly deteriorated. So my thought is I need 28' length with ends sitting on 8" of concrete block. Can I use 6 x6 x 16' pressure treated with a 4' lap joint glued and bolted together for a total of 28'? Only 2 x 6 decking will go on top.
woodmachine9 is offline   Reply With Quote
Old 10-20-2010, 02:08 PM   #2
concretemasonry's Avatar
Rewards Points: 2,716
What is the question besides trying to build a bridge with pieces of wood and glue.
I would not go over it since I do not know much about it, but spanning 28' is a stretch and the weather will kill it. The decking may be OK if it is only for an occasional bicycle traveling fast to get off before anything happens. You will definitely have a "belly" in the middle.
Sorry to be so short, but that is not much information to go on and give an approval.
Dick
concretemasonry is offline   Reply With Quote
Fabricating curved wood beams for bridge abraham Carpentry 7 06-21-2010 08:22 AM
30' x 8' creek bridge rtom Building & Construction 11 03-15-2010 12:34 PM
Hand-Made Stainless Steel Driveway Bridge - Elba, MN, USA jrico01 Project Showcase 13 09-28-2009 07:12 PM
rebuilding an old bridge jeaan Landscaping & Lawn Care 3 09-21-2009 12:15 PM
Help rebuilding porch please! catart58 Building & Construction 7 10-21-2007 10:35 PM
