Rebar Channel - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-02-2009, 02:01 PM   #1
Rebar Channel
I am using this type of block and need to create a channel for horizontal rebar. What tools and method could I use to create a channel similar to the one pictured? Thanks, Jim.
jrepp is offline   Reply With Quote
Old 06-02-2009, 03:34 PM   #2
Rewards Points: 150
Grinder with a diamond cutting wheel and a block hammer.
comp1911 is offline   Reply With Quote
Old 06-02-2009, 04:04 PM   #3
Concrete & Masonry
Rewards Points: 534
The block in the picture look lkie knock-out block. The reliefs are cast into the center webs so they can be hammered out easily for use as a bond beam. You wont be able to cut dep enough with a grinder in the center webs, so I would recommend getting the right block from a masonry supplier. You could rent a 14" concrete saw to saw deep enough, but you're probably farther ahead just buying the right block.
jomama45 is offline   Reply With Quote
Old 06-02-2009, 05:54 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 140
Does the rebar need to be in the center of the block? Can it be right at the top edge joint where two blocks meet. Should be simple to knock a chip out of the edge of the webs with a brick hammer to let a rebar sit on top of the block.
Old 06-02-2009, 07:06 PM   #5
Rewards Points: 1,232
Those are called RSBB units. They have holes in the bottom and are designed to be used with vertical and horizontal rebar. If that is all you have instead of solid bottom BB, then you can use a product like grout stop or even roofing shingles laid over the cores that you do not want to fill. The horizontal rebar is located where the knockout is, centered or doubled, as the case may be.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
How-To: cut a channel in concrete? vsheetz Building & Construction 7 01-31-2009 01:21 PM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 02:29 PM
Rebar for Monolithic Slabs portert0224 Building & Construction 1 07-03-2008 11:37 PM
Rebar Trees trout_baller Landscaping & Lawn Care 5 06-20-2007 05:39 PM
