Re-glueing Vinyl On Patio Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-12-2010, 12:36 PM   #1
re-glueing vinyl on patio door
Hi I live in michigan. Ihave a anderson patio door that has the vinyl coming unglued in two places. the weather is changing fast. I need to reglue these spots. what kind of glue do they use on the vinyl. the vinyl is on the weather side. thanks alot for some help.
craigsm is offline   Reply With Quote
Old 10-12-2010, 02:23 PM   #2
I would use a couple of dabs of PL200 on the underside of the vynyl and on the doorframe and hold in place with a moveable heavy object. Wait till dry and if you did it correctly should be fine.
greyowl is offline   Reply With Quote
exterior door on a level patio HChu Carpentry 6 10-08-2010 08:50 AM
How to replace a patio door Franky Building & Construction 2 09-24-2010 06:21 AM
Patio Door... Inside.. Any ideas? flipjarg Interior Decorating 10 10-21-2009 02:04 PM
Entry Door Size han Building & Construction 5 08-20-2009 07:54 AM
Patio Door Advice Mikedks Remodeling 2 12-18-2006 09:31 AM
