Thread Tools | Display Modes |
#1 |
I have gas!
Rewards Points: 1,900
![]() Rafter spacing
I'm building a hip roof over my deck.
I was planning on spacing the rafters at 15" but if I increase the spacing to 17.5" it makes the spacing much more even on the hip end of the roof. The roof is 12x16' and I'm using 3/4" plywood sheathing and 2x8 rafters. Is there any reason the extra 2.5" spacing would cause me problems?
I tear things down and build them up. |
Sponsored Links | |||
Advertisement |
#2 |
Rewards Points: 6,652
You would have to do some cutting for the odd ball spacing. 16" o/c to 24" o/c is standard.
The Following User Says Thank You to gregzoll For This Useful Post: |
BigJim (09-20-2014)
Advertisement |
#3 |
I have gas!
Do you mean cutting the ply for the odd spacing?
I wouldn't think that the rafters wouldn't really be affected. Mostly I was concerned with sheathing sag like I've seen on a few houses with really wide spacing. Edit: I just reread. No greater than 24" and I should be fine, right?
I tear things down and build them up. Last edited by Clutchcargo; 09-20-2014 at 12:30 PM. |
The Following User Says Thank You to Clutchcargo For This Useful Post: |
BigJim (09-20-2014)
Advertisement |
#4 |
Rewards Points: 144
What Greg is trying to say.If I may speak for you Greg is that ply comes in 48" wide sheets X 96" long which works out for 16" oc center spacing for studs and trusses.Been that way a long time.
If you go 15" that would be a 44 1/4" piece to start so you cut that sheet and then you have to offset the joint on the next piece.So more weird cutting and then the waste piece will not be usable.Go 17.5 more waste. Building materials are designed in the sizes they are for that application. Last edited by mako1; 09-20-2014 at 01:41 PM. |
#5 |
Rewards Points: 18,118
Also I've never seen a sloped roof sheathed with 3/4".
5/8 is enough. Any roofs I've seen with issue was caused by undersized rafters, no H clips between the rafters, old roof leaks or to many layers of shingles.
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
#6 |
MEASURE ONCE, CUT TWICE
Rewards Points: 1,438
There is no reason the spacing needs to be exactly 16" everywhere. It may work out that your last space is 12" or something, but that's OK.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/ |
#7 |
I have gas!
Got it.
Thanks guys.
#8 |
Figure out from the two ends one rafter there. Then figure out the spacing from the center of the house, working towards the ends. You may end up having a rafter within 6-7 inches from the two end rafters.
All of this, should have been noted on the building plans. |
Advertisement |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
rafter spacing question | markharmon | Building & Construction | 12 | 05-02-2013 09:12 PM |
rafter spacing for snow loads | ellsten | Roofing/Siding | 4 | 12-15-2011 03:56 PM |
removing rafter ties: garage conversion | neil_9 | New Member Introductions | 0 | 09-29-2010 08:55 PM |
Shed style porch rafter span and spacing | sjjacks | Building & Construction | 3 | 05-05-2009 07:17 PM |
Joist, rafter, and stud spacing for shed? | Badfish740 | Building & Construction | 2 | 10-27-2008 05:12 PM |
