Rafter Cutting Calculations - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-11-2010, 09:34 AM   #1
Why not
Rafter cutting calculations
Anyone know of any good forumlas for estimating how to cut rafters, etc. for roof framing
noahweb is offline   Reply With Quote
Old 02-11-2010, 09:56 AM   #2
General Contractor
Pythagorean Theorem
C (rafter) = the square root of A squared (rise) + b squared (run)
Then subtract 1/2 the width of the ridge board (If the ridge board is of 2x stock subtract 3/4").
Then add the length of the overhang.
Other methods you can research are:
Unit-length method
Step-off method
Rafter tables
Easier method:
Purchase a Construction Master calculator and follow the directions supplied with it. There is also software available that will calculate everything for you and give you a cut list.
ARI001 is offline   Reply With Quote
Old 02-11-2010, 12:52 PM   #3
jlhaslip's Avatar
Rewards Points: 708
give us your span, pitch, wall style, ridge beam measurement, rafter size, over-hang, and all the rest of the information.
Roof Framing Calculator Ver. 4.5
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 02-12-2010, 10:09 PM   #4
Rewards Points: 506
Read Carpentry by Ira Samuel Griffith....as well as the plethora of subsequent text out there in libraries and websites which cover this topic. And, when cutting rafters, don't estimate just calculate.
jlmran is offline   Reply With Quote
Cutting rafter ties ?? scatkins Building & Construction 23 04-13-2010 03:20 PM
Cutting rafter 66mustang Carpentry 7 03-23-2009 12:48 PM
Cutting a bird's mouth cut in a rafter? darsunt Building & Construction 4 02-20-2009 08:22 AM
Moving Attic Access -- Same Rafter or Different ?? wrldruler Carpentry 1 10-19-2008 06:03 PM
2x100a sub on service main jambud Electrical 17 03-12-2008 09:31 AM
