Quick Q Re: Finished Grade - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-27-2010, 04:10 PM   #1
Quick Q re: finished grade
Soon I'm going to begin digging a trench for a footing. The frost line is 36 inches from finished grade. I'm trying to figure out if finished grade begins at the top of the concrete slab that exists over soil, or does finished grade begin where the soil meets the underside of the concrete slab? I tried searching for this answer but found nothing. Thanks in advance.
JayG is offline   Reply With Quote
Old 03-27-2010, 04:49 PM   #2
kwikfishron's Avatar
Rewards Points: 930
I would say #1 but one quick call to your local building department and you'll know for sure.
kwikfishron is online now   Reply With Quote
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 12:53 AM
Moving ductwork to accomodate finished basement Badfish740 HVAC 1 01-13-2010 03:11 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
Below Grade Finished Basement Stays Around 55 Degrees diyourselfer Building & Construction 9 02-26-2009 07:11 AM
