Questions On Walling And Flooring Optiins - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-14-2015, 01:18 AM   #16
Rewards Points: 5,030
Are you planning on installing two washing machines.?
ron45 is online now   Reply With Quote
Old 09-14-2015, 08:07 AM   #17
Property Mgt/Maint
Rewards Points: 7,658
regarding the floor, the cheapest rout is simply to paint it, a step up would be epoxy floor coating. Rusto. makes a garage floor epoxy kit for concrete.
Another option would be indoor/outdoor carpet or commercial tile. Best floor the for space would probably be ceramic tile. If you were to find some tile at flooring outlet on clearance and lay them down yourself might be a reasonable cost option.
Regarding drywall over the OSB, I see no problem, I would still run the screws into the wall studs using 2" screws. Could also use construction adhesive and fewer screws.
[political signature removed]
Yodaman is online now   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
craig11152 (09-14-2015)
Old 09-14-2015, 10:26 AM   #18
craig11152's Avatar
Rewards Points: 1,220
Originally Posted by Hairic View Post
I live in southwest kansas if that helps anyone. Also this room is not heated or cooled at the moment
Don't you guys get pretty cold at night in the winter? Just thinking about the washing machine and hot water heater.
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
Old 09-14-2015, 11:20 AM   #19
Rewards Points: 948
I guess my questions are, is there any thing else I can use to finish the walls with, other than drywall
It should be drywall. Adjacent to a garage, it is a code requirement.
keymaster is offline   Reply With Quote
Old 09-14-2015, 12:25 PM   #20
Property Mgt/Maint
and probably 5/8 thk
Old 09-14-2015, 09:47 PM   #21
I would paint it.
Install the baseboard and door trim, painted.
Install painted lattice on all the seams.
Need Advice About Walling for Bath Remodel bremdogg55 Drywall & Plaster 7 12-05-2012 01:07 PM
