Question About Vinyl Siding, Tyvek And Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-24-2010, 07:53 PM   #1
Question about vinyl siding, tyvek and insulation
I was curious to try and find out the proper order for installing the following items. I have the exterior wall stripped down to the plywood. I have the interior down to the studs. I need to insulate the interior wall and maybe put plastic up as a vapor barrier on the inside. On the outside, I have installed tyvek on the plywood and foam board insulation over the top of that. Vinyl siding would be the last step.
Some concerns I've thought of recently are having too many moisture barriers. The home did have some moisture issues on this wall.
I suspect I'd skip the plastic on the inside and use regular insulation on the interior wall. On the exterior, I would have it layered as such: plywood, tyvek, fan fold insulation, siding.
Would this be correct?
thanks
brokenhammer is offline   Reply With Quote
Old 07-24-2010, 09:10 PM   #2
Rewards Points: 162
Don't skip the poly on the inside of the wall - you need it.
Tyvek is a moisture barrier, not a vapor barrier. Air can still move through it. You will still need a vapor barrier over the insulation/studs in the interior side of the room.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 07-24-2010, 09:55 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
and tape the seams of your foam
Tom Struble is offline   Reply With Quote
Window install question reguarding tyvek marlinpuppy Building & Construction 2 02-12-2009 11:56 AM
Tyvek with Spray Foam Insulation, Yes or No? Zinger Building & Construction 9 01-28-2009 04:29 PM
tyvek over wood or foam insulation guyfromMass Building & Construction 18 01-23-2009 12:05 AM
Tyvek application in crawlspace libwes Building & Construction 3 03-27-2008 11:45 AM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 06:39 PM
