Question About Door Opening Direction. - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-10-2011, 11:20 AM   #16
Originally Posted by epson View Post
If you have the private home entrance door swing outward then you will make it accessible to intruders. For this reason, the hinge mechanism needs to be positioned inside the house. With a standard hinge design, this means the door will open inward.
It's very easy to find hinges that can be used on outswing doors
mrgins is offline   Reply With Quote
Old 01-10-2011, 11:21 AM   #17
Originally Posted by oh'mike View Post
You can buy residential exterior doors that swing out---they have a different threshold than in-swing doors---As far as I know there is no code restrictions against using one--They come with self locking hinges --so break ins are prevented.
Special order--most houses want a screen door--that's why in-swing doors are more common.
I installed one on an inspected job last month---passed inspection.---Mike---
This is the correct response
The Following User Says Thank You to mrgins For This Useful Post:
oh'mike (01-10-2011)
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Simple question - proper direction of ceiling insulation jizzle Building & Construction 2 01-07-2009 09:08 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
