Putting Decking Over Cement Covered Porch - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-17-2010, 12:18 PM   #1
porch
can you put decking material over a cement porch, will i have problems with water underneath the decking (or between the decking and cement)
i cannot open the chat as i must have popup blockers, would you please email. thanks
mmandersen is offline   Reply With Quote
Old 06-17-2010, 12:22 PM   #2
What kind of decking material ?
You want to install it directly on top of the cement - that will trap moisture
Covered porch ?
Location ?
Old 06-17-2010, 12:43 PM   #3
it is a covered porch, nebraska. tough winters
hot summers
i will need to have it taken out then??? rats.
Old 06-17-2010, 12:57 PM   #4
putting decking over cement covered porch
I would like to put the no care flooring over my cement porch - my husband says it will have a water problem between the decking and the cement, from all i read - He is right, we will in nebraska, cold winters hot summers. is there anything else i can do besides take out the cement. thank you
Old 06-17-2010, 01:55 PM   #5
kwikfishron's Avatar
Rewards Points: 846
Originally Posted by mmandersen View Post
no care flooring
There’s no such thing.
You would need to have 2x sleepers on the concrete and then decking over that. It would raise the surface 2 1/2 - 3”.
kwikfishron is offline   Reply With Quote
adding a deck to existing concrete porch idiotbox37 Carpentry 6 12-02-2009 07:48 PM
tiling exterior covered porch with 3/4" osb subflooring nocarpenter Flooring 3 06-11-2009 03:12 PM
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 06:54 AM
Replacing covered porch support posts yousah Remodeling 4 09-30-2007 12:15 PM
Putting down a cement backerboard on floor Krichton Flooring 2 07-05-2006 02:13 PM
