Proper Way To Flash T1-11 Doors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-02-2014, 10:26 AM   #1
Rewards Points: 398
Proper way to flash t1-11 doors
Location FL
The siding on my house is similar to T1-11. It is just rough sawn pine siding with trim pieces to mimic board and batten. Currently, the 1x4 cedar trim pieces are just caulked to the windows and siding. This seemed to have held up for 30 years. I've replaced some of the siding and trim pieces and did not see any water intrusion.
I'm planning on installing some anderson double hung doors. Is there a way to flash T1-11? It acts as the sheathing and siding.
Malcolm is offline   Reply With Quote
Old 03-02-2014, 01:27 PM   #2
Davejss's Avatar
Rewards Points: 1,024
Just get some "Z" flashing and slip it under the T1-11 and over your doors and window trim, and then caulk and paint as usual.
Davejss is offline   Reply With Quote
The Following User Says Thank You to Davejss For This Useful Post:
Windows on Wash (03-06-2014)
Old 03-06-2014, 09:35 AM   #3
AHH, SPANS!!!
Rewards Points: 1,166
as davejss mentions do the z flashing and then possibly go over that with your 1x trim. the z flashing stops water penetration behind the trim but you do want to caulk the trim really well too especially the top edge against the T 1-11. you do not need the Z down the sides either just the top...
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
Old 03-07-2014, 11:51 PM   #4
Registered User
Rewards Points: 526
Is this the door, high impact resistant (required in FL), first one; http://www.andersenwindows.com/produ...ed-patio-door/ Notice #14 for metal drip cap as said already.
You can add trim in two different ways; 1x over the T-1 or 2x without T-1 under it, your choice. IMO, flash it 2 times, once above the trim and once above the door. Don't rely on caulking for long-term water resistance. Be sure to leave 1/4" at siding/door jambs and head. Bend the 90* to 117 or so as directed, no caulking except at ends next to where the end dams are. The trim will expand/contract at different rates/size to the structural siding. Use a sill pan under it or at least sticky tape, some guides, head flashing end-dams, pp.8, head flash, pp.10, and pp.18; http://www.mtcc1170.com/images/BCRainScreen.pdf At least sticky tape over the install brackets as directed.
Here is another one; panel wood siding, second group down; http://www.certainteed.com/Pros/Tool...g/CAD-Drawings
Be sure to use some low-exp. canned foam inside and poly backer rod under the caulking outside. Don't nail through the T-1/flashing below when attaching the trim.
Gary
Chemically Stripping Old Doors MsKitty32 Painting 10 01-24-2013 10:07 PM
Replacing 1-3/4" doors with 1-3/8" doors... brizak79 Windows and Doors 11 12-16-2012 12:22 PM
Can I get Custom 6 Panel Doors At Odd Sizes? heyjoe91 Remodeling 5 09-14-2012 05:54 PM
Installing new doors, floors, and trim. toobhed Windows and Doors 5 03-16-2012 03:21 PM
French Doors Don't Meet In Middle tima2381 Building & Construction 11 03-07-2011 06:42 PM
