Proper Re-framing Attic Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-02-2009, 06:03 AM   #1
Rewards Points: 151
Just curious of the proper way to frame an attic wall. If the wall runs parallel to the rafters but is placed in the middle of the rafter span, what is the right way to attach it to the ceiling. Do you run blocking in between the rafters or the collar ties? Separately, if your going to be moving an existing wall is it ok to nail it through existing hardwood floors (set it on top of the hardwoods) or should the hardwoods be removed and the bottom plate nailed directly to the subfloor.
gregt848 is offline   Reply With Quote
Old 10-02-2009, 12:26 PM   #2
Registered User
Rewards Points: 526
Do you run blocking in between the rafters--------- correct. Or add another collar tie and then block, 24"o.c. Over the hardwood.
Be safe, Gary
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 05:36 AM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
Attic Insulation Quote...what do you think? mitchel Roofing/Siding 15 08-06-2008 07:10 AM
I have a question on changing trusses, I am framing an attic room. wackerjr Building & Construction 17 01-22-2008 07:36 AM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
