Proper Fasteners For Beam/post/joist Intersection - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By woodworkbykirk
Old 07-03-2018, 11:30 PM   #1
Proper fasteners for beam/post/joist intersection
So I am building a deck, and I have a point where a post, the deck beam, and a joist all meet together as shown in the (crude) drawing attached. What would be the appropriate fasteners to use in this case? I can notch the post if needed.
Proper fasteners for beam/post/joist intersection-postbeamjoist.png
scottchantry is offline   Reply With Quote
Old 07-04-2018, 08:21 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 1,336
Re: Proper fasteners for beam/post/joist intersection
Use a double joist hanger for the joists. Is that what you are asking?
https://www.homedepot.com/p/Simpson-...8-2Z/100375219
You'll also need beam to post connectors like this, except in 6" https://www.homedepot.com/p/Simpson-...PC4Z/100375087
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 07-04-2018, 08:22 AM   #3
Knucklez's Avatar
Rewards Points: 1,002
pretty sure notching posts are no longer allowed by IRC. 3x2x10... that's one heck of a beam, you must be spanning a long distance or plan to support a monster load. the beam sits on the post via a metal bracket, and probably it will be in the middle of the post.
and then the joist meets the beam but its not so easy to attach because of the previously mentioned metal bracket. however, if you plan it out, you can drill holes in that metal bracket so you can connect the joist 2-2x hanger to it (nailing the hanger through the metal beam bracket and into the wood of the beam).
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 07-04-2018, 04:21 PM   #4
Is nailing through an existing fastener an acceptable practice?
Old 07-04-2018, 04:23 PM   #5
If I attach the post connector you suggested the way it shows in the installation diagram, it will block the joist hanger connection, or am I missing something?
Old 07-04-2018, 04:57 PM   #6
retired framer
Rewards Points: 6,188
What is the other hanger you are taking about, can you post a picture or link?
Old 07-04-2018, 05:00 PM   #7
Naildriver
chandler48's Avatar
Not really. The big flat piece will be on the beam pointed up while the two legs will be pointed down and on the side of the 6x6. Applying it on one side of the beam on the flat will suffice, while the joist hanger on the joist and attached to the other side of the beam will help hold the inner part. Yes, if you try to install one on the inside, it will occlude the installation of the joist hanger, although there is no prohibition from drilling through them both and using joist hanger screws on the flat should you want to install 2.
Larry......
Old 07-04-2018, 05:46 PM   #8
retired framer
We place hangers and drive nails thru flat straps on trusses all the time.
Old 07-04-2018, 09:33 PM   #9
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
notching 6x6 posts is fine because it creates a pocket for a beam to bear on.. if it carries up through for another level or pergola just make sure to fasten to the top of the beam using screws or connector plates
4x4 posts cannot be knotched and cant be used for bearing posts. only hand rail posts
woodworkbykirk is offline   Reply With Quote
Old 07-15-2018, 04:42 PM   #10
Knucklez's Avatar
i checked IRC and you are right. thanks!
interesting though the notch can't be deeper than 5" so that means beams are made of two 2x6 which will dictate your spans to next post
Proper fasteners for beam/post/joist intersection-6x6notch.jpg
Old 07-16-2018, 01:53 PM   #11
Rewards Points: 20
That's the max. bolt spacing, not the max. notch depth.
You can only notch for double beam, not triple.
A little more info would be helpful. Why are you not resting the joist(s) on the beam? What is the purpose of having those 2 joists sandwiched together? What is your max. joist span?
dmd5013 is offline   Reply With Quote
Old 07-19-2018, 05:50 PM   #12
its totally fine to notch for a 3ply beam as its will then provide full bearing on the post. if that post will be continuous you simply need to fasten down into the top of the beam .
ive never been questioned by a inspector doing so.. however i have been questioned by not having the beam fully bearing,, they have required hangers to be installed
Nealtw likes this.
Old 07-21-2018, 01:47 PM   #13
Rewards Points: 36
subscribed, this seems like a very interesting thread
pandes is offline   Reply With Quote
Tags
deck , fasteners
Proper way to install chimney pipe in metal building roof jonblack Building & Construction 15 01-31-2012 11:50 AM
proper way to terminal romex entering drywall Red Squirrel Electrical 10 03-03-2010 01:43 PM
proper material for service grounding rod? Jim S. Electrical 9 02-05-2009 10:25 PM
Help! What is Proper Way to Install Manufactured Stone? EricW Building & Construction 3 01-07-2007 04:56 PM
What is the proper ventilation needed? Ice Damns causing problems. alanisaacson Roofing/Siding 1 01-07-2005 02:38 PM
