Preventing Bamboo From Growing Back Through Shed Floor? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree6Likes
Old 11-08-2019, 10:01 AM   #1
Rewards Points: 108
Preventing bamboo from growing back through shed floor?
I am replacing this shed floor with 3/4 inch pressure treated plywood. How do I stop the bamboo from growing through it?
Preventing bamboo from growing back through shed floor?-20191108_095254_1573225254888.jpg   Preventing bamboo from growing back through shed floor?-20191108_095259_1573225278363.jpg
farmerjohn1324 is offline   Reply With Quote
Old 11-08-2019, 10:07 AM   #2
Rewards Points: 8
Re: Preventing bamboo from growing back through shed floor?
Can anyone pick out for me the best product among those listed on this site?
mosaictile is offline   Reply With Quote
Old 11-08-2019, 10:17 AM   #3
Rewards Points: 4,266
I would keep spraying roundup or similar on it every other week until nothing grows. After that, being dark underneath ought to keep anything from spreading into the area.
landfillwizard likes this.
stick\shift is offline   Reply With Quote
Old 11-08-2019, 10:18 AM   #4
Rewards Points: 108
So I wouldn't be able to put the floor back on for several weeks?
Old 11-08-2019, 10:36 AM   #5
Not without digging up all of the roots, IMO. I could be wrong but I could see the roots sending up shoots for quite a while.
Old 11-08-2019, 10:37 AM   #6
Rewards Points: 108
Yes I was doing some reading and it seems like I will have to dig them up.
By the way, do you think bamboo is strong enough to penetrate 3/4 pressure treated plywood?
Old 11-08-2019, 10:39 AM   #7
Rewards Points: 2,202
Armstrong Vinyl
Old 11-08-2019, 01:42 PM   #8
Rewards Points: 108
Do you think I should keep this steel frame? In a perfect world what should go under the plywood?
Preventing bamboo from growing back through shed floor?-20191108_095254_1573238531386.jpg
Old 11-08-2019, 01:54 PM   #9
retired framer
Rewards Points: 24,190
even concrete not thick enough can have bamboo grow thru it.
https://www.wikihow.com/Get-Rid-of-Bamboo
Do not use flat bottom gables with scissor trusses.
Old 11-08-2019, 01:57 PM   #10
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 126
Man....That bamboo is invasive.
We fought it at my daughters home and never won.
It was invading a fence line from a neighbors...I think I tried every chemical I could think of roundup root killer etc.
It just kept coming back....your situation may be a little different in that you can cover the whole bambo area and we could not attempt to kill the neighbors bamboo.
We just had to keep cutting it down/back....luckily my daughter sold that home.
While one would think both the dark and the 3/4 ply would stop it, I'm honestly not sure. Will you have sufficient weight in the shed in case it trys to grow and lift the shed. I would not think it could pierce 3/4 ply with tight joints.
MTN REMODEL LLC is online now   Reply With Quote
Old 11-08-2019, 02:06 PM   #11
Rewards Points: 108
Bamboo has also overrun the El Yunque Rainforest in Puerto Rico.
I'm putting the house on the market. So that's up to the new owners.
I could dig around the outside perimeter and put a vertical barrier, but I'm not sure I care that much.
MTN REMODEL LLC and Nealtw like this.
Old 11-09-2019, 03:29 PM   #12
Rewards Points: 2,550
IF you do discover a system/method/material to kill the stuff, do NOT post it here,,, instead, patent it & you'll be a millionaire annually,,, nevertheless, take heart - japanese bamboo is worse,,, at 1 time we used strychnine & vet hypodermic needles,,, it laughed at us
stadry is online now   Reply With Quote
Old 11-09-2019, 05:08 PM   #13
Rewards Points: 108
After doing some digging, I saw that some of it grew underneath from outside in the worst part. So I think I should dig a trench around inside perimeter of the shed and put a rhizome barrier in there.
Old 11-09-2019, 05:37 PM   #14
I doubt anyone has ever tried wicking both sides of the new growth leaves with a round-up saturated sponge.
Old Yesterday, 08:11 AM   #15
Rewards Points: 382
I doubt that would work. Bamboo is some tough MFing stuff.
Only thing that will stop it is a barrier trenched deep enough around the area you want to protect.
huesmann is offline   Reply With Quote
