Is Pressure Treated Required For INTERIOR Block Walls? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-07-2017, 12:58 PM   #1
Rewards Points: 74
Is pressure treated required for INTERIOR block walls?
Have an interior block wall that I would like to add some furring strips to and then drywall. I know treated wood is required anywhere it touches concrete or block on exterior walls. But if I have an interior block wall that is conditioned on both sides can I just use regular wood or does it still have to be treated if it is going to be touching the block wall? From googling I found a few sites that say interior walls that are conditioned on both sides you can use regular wood for furring strips. Just want to make sure before I attach them and find out treated is required.
ponch37300 is offline   Reply With Quote
Old 01-07-2017, 03:59 PM   #2
Rewards Points: 4,450
Re: Is pressure treated required for INTERIOR block walls?
What do you mean it's conditioned on both sides? It's not an exterior wall?
stick\shift is offline   Reply With Quote
Old 01-07-2017, 04:08 PM   #3
Rewards Points: 74
Correct. Not an exterior wall. It's just an interior block wall with living space on both sides. From what I read I should be able to use regular wood since it's not an exterior wall but I also read that any wood touching masonry should be pressure treated. Although I'm thinking thatost assume a block or concrete wall will almost always be an exterior wall so that is why they say that.
Old 01-07-2017, 08:31 PM   #4
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,528
Regular is fine. No moisture coming thru.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 01-07-2017, 08:48 PM   #5
Rewards Points: 74
Thank you.
Old 01-08-2017, 03:26 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
moisture wont come through the concrete but there is a chance it can come up through teh footing or slab if there isnt poly under the slab.. just as a precation staple some plastic or tar paper to the back of the wood lower down just to be safe
woodworkbykirk is offline   Reply With Quote
Old 01-09-2017, 07:46 PM   #7
Concrete & Masonry
Rewards Points: 464
Fairly common here, usually in post-war into the early seventies era. Rather than a steel beam with columns over footing pad, they poured a continuous strip footing with an 8" wide block wall to support the first floor load, with a door opening or two between the two sides.
jomama45 is online now   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
concretemasonry (01-09-2017)
Old 01-10-2017, 05:31 AM   #8
123pugsy's Avatar
I had this wall in my house. I always wondered what was up with that. At first I thought they added an addition or it was an afterthought to make it larger, but then I saw that the blocks were keyed into the outer wall's blocks.
Pressure Treated wood painting question sukhenkoi Painting 10 05-27-2015 10:31 AM
Have a bunch of pressure treated 2x4s - outdoor project ideas? hominamad General DIY Discussions 8 04-20-2015 11:40 AM
Can you have hyrostatic pressure around your basement if only three walls are below? mikegp General DIY Discussions 9 12-02-2011 10:10 PM
Hybrid Deck - Is Pressure Treated + Composite Feasible? kyassassin Building & Construction 4 01-15-2009 09:33 PM
pressure treated or pre-stained?? farrington135 Landscaping & Lawn Care 2 05-03-2007 10:04 AM
