Prebuilt Trusses - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 10-16-2019, 07:04 PM   #16
Rewards Points: 7,726
Re: Prebuilt trusses
Even though they are trusses I would expect that after 46 years they are now applying some load to any walls below. That doesn't mean all would fall down, just that some new settling may occur and some drywall cracking.
If it were me I'd be talking to my truss supplier with a lot of pictures in hand. Give him a chance to demonstrate his knowledge like, are these trusses?? Then see what he adds to your knowledge base.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
The Following User Says Thank You to Bud9051 For This Useful Post:
slinger58 (10-16-2019)
Old 10-16-2019, 07:10 PM   #17
Old Paint Contractor
Rewards Points: 104
Bud
Thanks, Bud. Sounds logical to my uneducated mind.
slinger58 is offline   Reply With Quote
Old 10-25-2019, 10:59 AM   #18
Rewards Points: 104
Originally Posted by Nealtw View Post
But after saying that I found this.
Continuing my research on prebuilt trusses, I found a drawing of a truss that looks exactly like that Howe girder and it was called a tribearing truss.
Nothing is ever simple is it?
Old 10-25-2019, 11:10 AM   #19
retired framer
Rewards Points: 4,588
I found that too, but I also found where it said can be used as multi bearing.
But if it is multi bearing you would have to have support under one of the uprights for every truss. If one of them has no bearing under any of the uprights, then it is not used as a tribearing. If one is not tribearing then non are. I am sure you have no problem.
Do not use flat bottom gables with scissor trusses.
The Following User Says Thank You to Nealtw For This Useful Post:
slinger58 (10-25-2019)
Old 10-25-2019, 11:20 AM   #20
retired framer
If you are still worried about it drag some 2x4s up there and put a chevron of braces over the area that you will be removing the wall.
Do the braces on the center upright.
