Prebuilt Trusses - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 10-16-2019, 05:07 PM   #1
Old Paint Contractor
Rewards Points: 104
Prebuilt trusses
Iíd like to remove an interior wall and Iím trying to determine if the wall is load bearing. Iíve been told by some carpenters that since I have prebuilt trusses, only the outside walls are load bearing. Others have said thatís not necessarily so and my little bit of google research has not made it any clearer.
Iíve been a painting contractor for the last 35+ years so Iíve been around construction most of my life. Iíve gained a little knowledge of some of the other trades but Iíll readily admit I know next to nothing about framing.
Hopefully my pics will attach to my post and be helpful. The trusses span approximately 28í all the way down the length of the house (70í). The house is 46 years old.
Any advice or opinions are appreciated.
slinger58 is online now   Reply With Quote
Old 10-16-2019, 05:12 PM   #2
Rewards Points: 104
Re: Prebuilt trusses
And I forgot to post the pics. Itís tough getting old.
Old 10-16-2019, 05:12 PM   #3
Rewards Points: 104
And one more.
Old 10-16-2019, 06:11 PM   #4
retired framer
Rewards Points: 4,588
You don't have any load bearing walls in there.
The safe bet is just finding a picture of the truss you have, yours look to be Howe girder
I have never found pictures on line that indicate three or four bearing points.
Do not use flat bottom gables with scissor trusses.
The Following User Says Thank You to Nealtw For This Useful Post:
slinger58 (10-16-2019)
Old 10-16-2019, 06:16 PM   #5
Rewards Points: 104
Thanks, Neal. Yes, the Howe girder looks exactly like what I have.
Old 10-16-2019, 06:19 PM   #6
retired framer
But after saying that I found this.
Old 10-16-2019, 06:22 PM   #7
retired framer
See my post 6, I don't believe you have a problem but this might be a question for a truss company. they would consider the length the pitch and the snow load for your area.
Old 10-16-2019, 06:24 PM   #8
Rewards Points: 104
I remember finding one during my google search that looked like mine that was called a ďtri-bearing ď truss.
Hence the confusion.
Old 10-16-2019, 06:26 PM   #9
retired framer
Anytime we get multi bearing trusses the extra wall will be right in line with one of the uprights, The would not put any load in between the uprights in the truss.
Old 10-16-2019, 06:27 PM   #10
Rewards Points: 104
Snow isnít a factor here in the sunny South. How would the pitch affect it it?
Old 10-16-2019, 06:31 PM   #11
retired framer
The more the snow load the higher the pitch would be.
Old 10-16-2019, 06:35 PM   #12
Rewards Points: 104
The wall being considered for removal is offset 2í from center. And in the garage the storage room wall is offset 7í from center. Same type trusses all the length of the house.
Old 10-16-2019, 06:41 PM   #13
retired framer
Unless all of them are supported under one of the uprights, they would not have trusses and tri bearing in the same row for no reason. I think you are good to go with the big hammer.
Old 10-16-2019, 06:52 PM   #14
Rewards Points: 104
Thanks again, Neal. I helped a friend and his carpenter take out a bearing wall about 25í long last Saturday. He had to put in some ďLVLĒ beams (?).
Man, what a process! If I can avoid that Iíll count my lucky stars.
Nealtw likes this.
Old 10-16-2019, 06:58 PM   #15
Rewards Points: 104
And as a bonus here, if I post 7 more times Iíll regain access to the CBR.
When they upped the post requirement to 100, I got locked out. I never posted much there but I kinda enjoyed reading the spirited debate.
Nealtw likes this.
