Post And Beam Attachment - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-21-2010, 10:34 AM   #1
Post and beam attachment
I'm building a free standing deck next to a pool with 6x6 posts. I was referring to the link to the American Wood coucil I found in a couple of posts and had a couple question. Great site thanks in advance
FOund this posted BY GRB_IN_WA; great document
http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
Does it make a difference if the notch on the post holding the beam is pointing outward toward the rim joists or in toward the center of the deck? See picture 1. Should the other set of post and beams be notched toward the outside?
On the notched method would it not be better to have the notch in the middle of the post between the two beams?. So in the 2nd picture there would be a notch on both sides of the post.
I have always used the "Sandwich" method why is that no longer recommended?
On the cap type that would be and nice clean solution but I've on ly seen those for 4x4 posts do they make for 6x6?
Post and beam attachment-relationtorimoist.jpg   Post and beam attachment-notched1.jpg   Post and beam attachment-sandwichbeam.jpg   Post and beam attachment-cappedbeam.jpg
DIY1963 is offline   Reply With Quote
Old 07-21-2010, 12:27 PM   #2
Below is a diagram of the deck i'm planning. Every picture with the notch seams to have both sets of beams on the same sid of the post.
thanks
Old 07-23-2010, 07:53 AM   #3
thanks
Here are the answers I found out
1. Does not matter which side the notches are on the beam whichever is easier.
2. the method with the beams sandwiched around the post has all the weight ont he carriaige bolts
Old 07-23-2010, 03:39 PM   #4
Old School
Willie T's Avatar
You've already got most all of the information that you need in the guide. I'd say you're on the right track.
Willie T
Old 07-23-2010, 10:24 PM   #5
Registered User
Rewards Points: 526
Put a bead of caulking down each side of the notch where the beam sits, leave a small opening for any trapped water to exit. Install sticky window wrap on the whole beam top and the post joint, full length to help protect from water. Treat the post and notch with water-proofing as p.t. wood is not. Lay a continuous caulk bead along the drip edge of the house ledger at the bottom outside edge to keep water from blowing back. Fill just each end of the bolt hole with caulking after the bolt/washer is installed, before the washer/nut. Use a deck cleaner and sealer/stain right away, if p.t. wood. http://www.thompsonswaterseal.com/advice/faq.cfm
Be safe, Gary
Old 07-25-2010, 08:25 AM   #6
so far
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 08:39 PM
New deck - Gap between beam and post due to shrinkage? DaveNJ Building & Construction 3 07-06-2010 07:23 AM
beam extends beyond post jklingel Building & Construction 10 06-14-2010 10:20 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
Deck Beam connection to Post? CNJHomeowner Building & Construction 7 08-08-2008 06:14 AM
