Porch Railing Question - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Bondo
  • 1 Post By barbiaux
Old 06-25-2016, 08:15 PM   #1
Rewards Points: 6
Porch railing question
I have asked a bunch if questions about our new porch and I am down to installing the railings finally. When we originally did our plans we were installing 6x6 posts and wrapping them in faux stone from texture plus. Our plans had us using 2x6 for the railings. Our house is on a hill so it is about a 20 foot fall from our porch. We wanted to use 2x6s so it would be much stronger but apparently there are no brackets to attach them to the 6x6s. I had planned on having the railing go from the inside of the 6x6 to the inside of the next 6x6 and installed so the long side is facing up. It just seems there is no way to attach this. I figure simpson would have something but there is nothing that I can find. Do people not use 2x6 for railings? If so, how do you attach them?
barbiaux is offline   Reply With Quote
Old 06-25-2016, 10:48 PM   #2
JUSTA MEMBER
Rewards Points: 1,456
Re: Porch railing question
I am confused .
You stated "the long side facing up", do you mean the 5.25 in side is up, or do you mean the length of the 2X6 is up?
Yes people use 2X6 as railings often.
I would fabricate my own brackets from some 2 or 3 inch angle iron, cut to the length needed to lay the 2X6 on and screw it to the bracket, and the bracket to the post.
This bracket is on the underside of the 2X6 and partially hidden.
ED
de-nagorg is offline   Reply With Quote
Old 06-25-2016, 11:28 PM   #3
Rewards Points: 6
Yes that is correct. The 5 inch side would be facing up. My dad said the same thing about just making the bracket with angle iron. I am just surprised that there aren't simpson brackets already.
Old 06-25-2016, 11:36 PM   #4
JUSTA MEMBER
I would also make them from either Stainless, or Aluminum, not regular iron, it rusts too fast.
ED
Old 06-27-2016, 06:46 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 144
Ayuh,.... Tip 'em out alittle bit,.....
Abit of pitch away from the porch will drain the water off, 'n they won't rot as quickly,....
Put the cup of the end-grain, down, helps with drainin', 'n warpage,....
Ditto buildin' yer own brackets,...
de-nagorg likes this.
Bondo is online now   Reply With Quote
Old 06-27-2016, 07:34 PM   #6
Rewards Points: 6
Thank you for all the replies. I was going to buy sone today and realized there many thicknesses. What us recommended, I was going to buy 1/4, would that be strong enough. Oh I guess type would be important, probably going to use aluminum.
front porch question markharmon Building & Construction 0 07-08-2013 04:26 PM
new porch railing tbone1072011 Building & Construction 2 10-15-2012 05:09 PM
Attaching porch railing to brick wiz561 Building & Construction 0 06-19-2011 02:39 PM
front porch railing coming away from columns silent1643 General DIY Discussions 7 10-07-2009 10:54 PM
Porch rebuild question Unregistered General DIY Discussions 1 11-26-2004 05:20 PM
