Plywood Spacer On Top Of Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Daniel Holzman
Old 08-01-2016, 09:52 AM   #1
Rewards Points: 30
Plywood spacer on top of beam
Is it a-ok to put a plywood spacer on top of a beam and then put floor joists on top of the plywood? The plywood won't overhang the beam any, just on top of it. I assume the plywood can hold the weight without compressing but thought I would make sure before I did it and have to tear it up for the inspector...I need to raise the beam about 1/2in
Edu.wes is offline   Reply With Quote
Old 08-01-2016, 10:40 AM   #2
Rewards Points: 4,464
Re: Plywood spacer on top of beam
I would raise the beam, then, not put something on top of it. Why is this needed in the first place?
stick\shift is offline   Reply With Quote
Old 08-01-2016, 10:55 AM   #3
Rewards Points: 558
Use outdoor rated ply and dry. load bearing walls and posts are set on the plywood all the time. Use long lengths and check for voids. I wouldn't use ply shims under the beams where the support loads are concentrated. Metal shims for those.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
woodworkbykirk (08-02-2016)
Old 08-01-2016, 11:25 AM   #4
Rewards Points: 30
Beam is on top of concrete, with a standoff
Old 08-01-2016, 11:27 AM   #5
Rewards Points: 30
Joists intersect the beam, they arnt completely supported. So metal shims probably?
Old 08-01-2016, 01:59 PM   #6
Civil Engineer
Rewards Points: 5,246
What do you mean joists "intersect" the beam? Are the joists above the beam, flush with the beam, or below the beam?
Old 08-01-2016, 04:31 PM   #7
Rewards Points: 30
Above the beam, sitting on top of it
Old 08-01-2016, 06:03 PM   #8
Civil Engineer
Perfectly acceptable to use plywood for shims in this type of application, if the gap is uniform you can use a long piece of plywood to handle multiple supports. Check with your building inspector first to make sure they agree.
craig11152 likes this.
Old 08-02-2016, 12:47 AM   #9
Registered User
Rewards Points: 526
"Shims for floor joist or girders shall be of hardwood or steel plates or other wood which is not easily compressible, tight grained to resist compression, and rot and pest resistant. Shim width shall not be less than girder width, i.e. a 4" -------------from 2012 IRC, don't know if you are under it or not... check locally for sure... of course it may not compress much; http://www.eng-tips.com/viewthread.cfm?qid=371840
Gary
Old 08-02-2016, 09:54 AM   #10
craig11152's Avatar
Rewards Points: 1,220
I'm no expert and don't know codes but just as an observation when people around here frame a second story on a house, even a third story the walls often sit on a plywood subfloor.
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
Old 08-02-2016, 02:29 PM   #11
Rewards Points: 1,676
There is a difference between the force exerted by a wall spread over 3 1/2" or 5 1/2" width and a decent length and a joist hitch is supported that is putting the weight of normally half of its length on a 1 1/2" inch area. That said, everyone I've seen uses plywood!
ront02769 is online now   Reply With Quote
The Following User Says Thank You to ront02769 For This Useful Post:
carpdad (08-02-2016)
Old 08-02-2016, 09:09 PM   #12
Rewards Points: 558
Are you trying to confuse me?
Old 08-02-2016, 09:41 PM   #13
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
plywood shims are perfectly fine.. unless its multiple layers of plywood especially if there is a point load location then use steel
woodworkbykirk is offline   Reply With Quote
Old powder post beetle damage to beam in basement - is it really a problem? nezwick Building & Construction 5 10-09-2012 10:12 PM
Need help with bad beam LVDIY Building & Construction 55 07-12-2012 07:31 PM
Which beam is stronger? D270 Building & Construction 19 04-19-2012 08:17 AM
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 01:08 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 02:07 PM
