Please Help Me Fix This Problem - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-01-2009, 10:08 AM   #1
My electric wire was anchored to a 2x4 now it's pulled from my roof. The electric co. says I have to put it back first. The 2x4 was nailed underneath the soffit. Can I nail a 2x4 back up without removing the soffit first?
It looks like everything will pop back into place. I have no experience with this whatsoever. I know I have to buy a new piece of wood & nails. It looks like 3 inch nails were used. Can I just hammer these back in? Do I need any special tools to get the nails in. Am I nailing into concrete or wood? The electric co. will replace the circle piece where the wire is attached to the 2x4.
Any suggestions will be very much appreciated!
eta. the electric co says it's okay to fix this issue without being electricuted as long as i don't cut the wire. which i won't be doing!
http://img526.imageshack.us/img526/8620/imgp0232m.jpg
HandyMandy is offline   Reply With Quote
Old 07-01-2009, 10:19 AM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 2,040
That's a cheesy way to hang the cable and it will look bad.
I think I would hire an electrician to either hang it properly or replace the entire cable and add conduit.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 07-01-2009, 12:01 PM   #3
I agree ClutchCargo. That's how most of the cables are hung in my neighborhood. I have no idea why they hung it that way
Old 07-01-2009, 12:08 PM   #4
So you just need to re-attach the 2x4 & then they will re-connect the wire?
Mine have always been attached to a strong beam 2x10 etc
Old 07-01-2009, 02:17 PM   #5
Rewards Points: 1,910
You mean the power is still live and they said you won't fry if you don't cut the wires?
If the power is still live you could easily kill yourself!!!!
Please let an electrician handle this one. There's many many better things to attempt DIY that aren't life threatening.
Old 07-01-2009, 04:58 PM   #6
Even if those wires are dead,as they look,leave this to an electrician.If you get the right guy he will correct that mess by properly supporting and rewiring it.It is obvious from the questions you ask that pro help is needed and high voltage electricity is not a good place to learn. Just my opinion,don't want you to get hurt or burn your house down.
white29 is offline   Reply With Quote
Old 07-01-2009, 06:55 PM   #7
What you have there, will not just pop back into place.
Obviously the method that was used was unsafe, as is witnessed by your photo's.
It is my guess that this type of installation was carried out before WWII. At least in my area it wouldn't have been allowed since 1945.
A licenced electrician will have to hired and a permit taken out. This will probably require a 'stack' to be installed along with a new meter base and electrical panel.
Assuming that the NEC applies in your area.
Problem with fan coil unit/hydronic system. flood1911 HVAC 2 09-05-2008 04:57 PM
2 switches , one light problem pepperthecat Electrical 2 07-08-2008 03:57 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 03:16 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
