Plastic Storm Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-28-2014, 01:01 PM   #1
Rewards Points: 2
plastic storm windows
I'm planning to enclose an open, south facing porch with 2"x 4"s to function like large picture frames using plastic sheeting to cover the openings. The openings are about 3' above the floor and goto the ceiling. My goal is to keep the snow out of the porch. What mil should be used that is economical? I have the 2"x 4"s. There are 7 openings that are 42"x64" and another one will be like a hinged door. I started looking on line for 20 mil. Is that too heavy, or unnecessarily heavy? I plan to wrap the edges of the plastic around lattuce strips and then tack them to the 2"x4"s. These will be removed in the spring. Is there a better way?
This is a town house and the porch faces the street where there is another row of 30 houses across the street.
Ruthbb is offline   Reply With Quote
Old 10-28-2014, 08:36 PM   #2
Rewards Points: 638
reinforced poly ??
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 10-29-2014, 08:13 AM   #3
Rewards Points: 9,780
Myself, I would be looking for rigid sheets, but of course they are going to be more expensive. If you Google "greenhouse supplies" you will find suppliers who sell film and sheets that are known to be UV resistant. The first one that popped up when I did a search showed they sell film in 3 mil to 6 mil thickness. If the film is not UV resistant, its going to turn yellow and eventually crack, but with your plan, it would be pretty easy to replace.
SPS-1 is offline   Reply With Quote
Old 10-29-2014, 05:57 PM   #4
Rewards Points: 1,042
6 mil would work if it's uv resistant.
Canarywood1 is offline   Reply With Quote
Old 10-30-2014, 05:02 PM   #5
Rewards Points: 5,142
http://www.windowinserts.com/?src=overture
ron45 is offline   Reply With Quote
Exterior Storm Windows Fins59 Windows and Doors 28 02-10-2013 09:48 AM
Wooden Windows or Plastic? Richuw Windows and Doors 15 04-05-2012 10:16 AM
Andersen vs Jeld Wend Replacement Windows ... JasonCA Remodeling 13 03-20-2012 10:46 PM
Can you flash replacement windows with existing siding? twobyfour2 Windows and Doors 3 05-31-2011 09:29 PM
Plexiglass storm windows simmonsal1953 Building & Construction 3 06-30-2009 04:23 PM
