Plastic Doorrknob Removal In Mobile Homes - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-15-2010, 12:23 PM   #1
plastic doorrknob removal in mobile homes
I live i a 30 yr old Centurion Mobile home. The bathroom door in the main bath wont lock so I thought I would change it out with a closet doorknob that does lock. I cant get either doorknob apart to change them. They are plastic knobs and I don't see any screws or hardware. Thanks.
Shane
ShaneR is offline   Reply With Quote
Old 12-15-2010, 02:49 PM   #2
Look at the plates behind the knobs. If you see a little slot there, you should be able to insert the corner of a flat screwdriver, and carefully pop the plate loose, and that may give you access to the screw that you are looking for.
Old 01-14-2011, 08:51 PM   #3
If you have yet to figure out how to take the plastic knob off, a lot of them actually just pull apart. If you have one person hold on of the knobs, and another pull on the other one, it should pop apart. Good luck (:
xeinozu is offline   Reply With Quote
Primer to paint vinyl-covered "wallpaper" panels in mobile homes? LThompson Painting 13 02-24-2012 12:16 PM
carpet removal from residential homes t1502 Off Topic 0 08-28-2010 11:02 AM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 04:47 PM
Plastic Sleeve Removal Outdoorbum Plumbing 1 07-04-2009 10:30 PM
Mobile Homes kbel Building & Construction 1 06-10-2008 09:42 AM
