Plastering, Stuccoing Exterior Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-19-2010, 09:48 PM   #1
plastering, stuccoing exterior wall?
I have done many of diy projects, but i have never done exterior wall work. Please forgive the ignorance. Can you tell me what the basic steps are to plaster an exterior wall? i.e. do I put sheathing, paper, wire mesh and some sort of mudd then a final coat with knockdown texture? Please help me! Thank you for your time
rsclark67 is offline   Reply With Quote
Old 04-21-2010, 10:10 PM   #2
anyone, help!?
Old 04-22-2010, 03:11 PM   #3
Rewards Points: 5,348
There are a few stucco techniques. Old school would be to use 30 lb tar paper. Install wood lath vertically every 16" and put galvanized wire diamond lath over that. You'd apply a scratch under coat and then a top coat. The other way would be to use a synthetic stucco over a foam base. Try going to Youtube, I'm sure they'll have videos on both.
Stuccoing is a skill set that has a fairly steep learning curve.
Ron
Old 04-30-2010, 10:25 PM   #4
Thank you for your help. I had the hardest time trying to get the sequence , but now the task is completed and it turned out pretty good. Quite the task, i must say.Have a great day/night!
Plastering help Plaster Brokers New Member Introductions 8 02-01-2009 08:42 PM
Paint Bubbles after Plastering anthony9887 Painting 8 06-12-2008 11:45 AM
plastering or drywall section? Plaster Brokers Site Help and Suggestions 0 07-27-2007 09:26 PM
Plastering Mix Liamsbab Building & Construction 3 05-29-2007 05:14 PM
Plastering on newly laid brickwork? djj66 Building & Construction 10 09-21-2005 12:01 AM
