Plaster Walls Covered With Panelling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-06-2014, 12:22 PM   #1
Plaster walls covered with panelling
We have a room where the plaster walls are covered with panelling. We were able to peek behind a piece and it looked as though there were a lot of cracks. If the walls are falling apart underneath, is the option of just drywalling over them completely dead in the water? We have absolutely no way of repairing the old walls but loathe the panelling.
yakusoku82 is offline   Reply With Quote
Old 03-06-2014, 02:02 PM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,470
Originally Posted by yakusoku82 View Post
We have a room where the plaster walls are covered with paneling.
Whether they're actually plaster or just a skim coat over something else the previous owner went with the cheap fix of paneling.
If the walls are falling apart underneath...
Ideally you'll remove the paneling AND whatever the wall is right down to the studs. Then you can start over, including insulation, with fresh sheet rock.
You could also just remove the paneling and apply THIN sheetrock. But it's hard to make that call before you have the mess on the floor.
Old 03-06-2014, 05:40 PM   #3
Rewards Points: 268
Been dealing with this room by room in my 100 year old home. I kept the plaster on the walls that were semi flat with few cracks (it's 3/4-1" thick and is probably my main insulation!)
But 2 bedrooms and the old kitchen (now just an extra room) had bad, bad cracking and separation from the lath. So down came the plaster. It is a dusty, dirty, and extremely heavy exercise, I'll tell you. 5 gal buckets and a dumpster will be your friend. Then I went with the thickest drywall I could find after insulating every nook and cranny.
Good luck!
Marqed97 is offline   Reply With Quote
Old 03-06-2014, 06:04 PM   #4
Rewards Points: 18,232
Should have been fire blocked at the top and bottom of the walls, air seal any gaps, wiring up dated, insulated, vapor barrier before the sheetrock.
Old 03-06-2014, 07:44 PM   #5
Rewards Points: 268
For me, that's all a given. Considering the walls were down to studs for about 6 months. Nothing happens fast around here.
Old 03-07-2014, 07:52 AM   #6
Why is there no way to fix it right?
Peeling Paper off of Plaster Walls train_rider Drywall & Plaster 4 03-25-2012 08:50 AM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 02:20 PM
Filling low areas in plaster walls Nayehi Remodeling 2 10-08-2010 06:53 PM
rewiring house with plaster walls mattrussin Electrical 3 09-27-2010 08:41 AM
Remodeling a half bath with plaster walls rh8868 Kitchen & Bath Remodeling 26 01-28-2010 01:14 AM
