Plants Growing In Laundry Room - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-29-2012, 11:43 PM   #1
plants growing in laundry room
My laundry room is on top of a concrete slab (used to be a porch from what I can tell). In the corner, there is a plant growing through the slab and up the wall. What's the best way to remove this/keep it from coming back? I'm already drooling over the fact that there may be water behind the drywall.
Tonglebeak is offline   Reply With Quote
Old 04-30-2012, 12:48 AM   #2
Rewards Points: 18,118
More likly it's rooted outside and has grown up under the siding and into the house.
Spray some total vegatation killer around the outside of the house.
Old 04-30-2012, 08:28 AM   #3
Rewards Points: 6,652
Spray the area down with Roundup, then either use Caulk, or the vinyl concrete sealer from Sakrete, that comes in half quart bottles, that you can squeeze the mix after shaking, to seal the area. Also address from the outside with caulk, after inspecting for any water damage, and fixing.
Laundry Room Addition Completed hyunelan2 Project Showcase 6 02-27-2011 11:42 PM
One room cold- what pipes are what...help cciampi HVAC 24 02-20-2011 12:44 PM
laundry room wiring brit in canada Electrical 3 01-07-2011 10:45 PM
Well Room (Cold Room) Issue--Advice Needed TomPgh Building & Construction 11 01-03-2011 07:31 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
