Thread Tools | Display Modes |
#1 |
Landlord
Rewards Points: 89
![]() Placement for 6x6 Cedar Posts on front of house
Hello, I'm going to be renovating my rental early next year, and I'm going to add cedar accents to the front of the house(posts on front porch and cedar board and batten shutters)
What would be the best placement of these posts? The porch is supported with no posts as is. Should they be spaced equally? I was thinking of one on each side of the front door and one maybe in front of the big window...see for yourself |
Sponsored Links | |||
Advertisement |
#2 |
Rewards Points: 5,348
I wouldn't put anything in front of the window to block the view.
I'd put up 4 posts. One on the left, one on the right and a pair on either side of the door.
Ron "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." B. Franklin 1759 |
Advertisement |
#3 |
Landlord
Rewards Points: 89
something like this...
Advertisement |
#4 |
Seems like a lot posts in a small area. How long is the porch?
#5 |
Landlord
Rewards Points: 89
that's the problem...prolly about 15 ft
what would look the best is probably a post cut down the middle lengthwise and attached to each wall, but that is probably too costly |
#6 |
Landlord
Rewards Points: 89
this house is close to it
#7 |
Rewards Points: 948
If you must have them (and I'm not convinced) then one on either end, one in the middle. Keep the spacing identical. Take the photo you provided and remove the second one near the door.
I think there are things you could do that would make a bigger difference, paint for instance. |
#8 |
Rewards Points: 948
![]() If that's the look you're going for, notice the fascia dimension, trim, railing, paint color, paint scheme. (Rustic cedar doesn't jive with it.) The post layout you showed below could work with some massaging, if tied together by a rail. Don't use a full post at each end, but a half column at the wall. Edit: Also, 4x4 post with a pvc wrap might work. The post isn't structural. Last edited by keymaster; 08-29-2015 at 12:02 PM. |
Advertisement |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
[Staining cedar home] Over my head... need advice on materials, approach | Triboost | Painting | 13 | 07-22-2015 07:29 PM |
Cape Cod Style House Attic/Crawl Space Insulation Help | Danielg | Insulation | 24 | 05-21-2012 09:20 AM |
Buying house with Cedar Siding | mitch12533 | Painting | 9 | 12-06-2011 05:43 PM |
What to do with the front of this house? | Clemsig07 | Remodeling | 4 | 05-23-2011 07:57 AM |
Complete AC installation in Old Capitol Hill Row House | jacko10 | HVAC | 0 | 09-18-2007 06:42 PM |
